* | user: Move "Ecosystem" into "Introduction" | Sebastian Huber | 2019-01-14 | 3 | -242/+239 |
* | user: Move "Support" to "Introduction" | Sebastian Huber | 2019-01-14 | 3 | -128/+125 |
| | | | | | New users may find it useful to get this information in the introduction. | ||||
* | Reformat and update copyright and license notices | Sebastian Huber | 2019-01-14 | 14 | -99/+90 |
| | | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | ||||
* | user: Add RSB content as a chapter | Sebastian Huber | 2019-01-14 | 14 | -81/+33 |
| | | | | Remove the separate RSB manual. | ||||
* | user: Remove unused file | Sebastian Huber | 2019-01-11 | 1 | -10/+0 |
* | common/header: Add missing copyright notice | Sebastian Huber | 2019-01-11 | 1 | -0/+4 |
* | rsb: Reword some sentences | Chris Johns | 2019-01-11 | 1 | -6/+6 |
* | rsb: Move content of duplicate section | Sebastian Huber | 2019-01-11 | 4 | -66/+24 |
| | | | | | Move "Controlling the Tools Build" section and "Building Tools and RTEMS" chapter to "Project Sets" chapter and "RTEMS" section. | ||||
* | rsb: Move "Why Build from Source?" to own chapter | Sebastian Huber | 2019-01-11 | 3 | -56/+60 |
* | rsb: Move "History" to own chapter | Sebastian Huber | 2019-01-11 | 3 | -33/+38 |
| | | | | Move it to the end of the document. It is auxiliary information. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 272 | -272/+272 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 178 | -178/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 235 | -378/+262 |
* | user: Add TODO entries for all BSP families | Sebastian Huber | 2019-01-09 | 16 | -6/+370 |
| | | | | Update #3464. | ||||
* | rsb: Fix chapter layout | Sebastian Huber | 2019-01-09 | 1 | -3/+0 |
* | user: Rework overview | Sebastian Huber | 2019-01-09 | 3 | -31/+233 |
| | | | | | | Move "Overview", "Real-time Applicaiton Systems" and "Real-time Executive" chapters as sections into new "Introduction" chapter. Add "Feature" section. | ||||
* | Update header.rst | Sebastian Huber | 2019-01-09 | 1 | -10/+10 |
| | | | | Remove trailing slashes in URLs. Fix bug reporting URL. | ||||
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 15 | -322/+37 |
* | Remove superfluous word "Copyright" | Sebastian Huber | 2019-01-09 | 1 | -1/+1 |
| | | | | The © symbol is sufficient. | ||||
* | Update general copyright notice | Sebastian Huber | 2019-01-09 | 1 | -1/+1 |
| | | | | Update year and add "and contributors". | ||||
* | Replace build date with Git hash and commit date | Sebastian Huber | 2019-01-09 | 3 | -47/+39 |
| | | | | The usage of a build date prevents reproducible builds. | ||||
* | cpu-supplement: Update ARM multilibs | Sebastian Huber | 2019-01-07 | 1 | -7/+18 |
* | c-user: Fix typos | Frédéric Jouault | 2019-01-04 | 2 | -4/+4 |
| | | | | Close #3261. | ||||
* | sparc_v8_stacks_regwin.rst: Add middle initail for Peter Magnusson | Joel Sherrill | 2018-12-20 | 1 | -2/+2 |
| | | | | | | Peter requested this after reviewing the converted content. He noted that it was a nit but he had consistently used his middle initial in all academic settings and wanted to be consistent. | ||||
* | Eliminate UTF-8 characters except superscripted 2 in i2c | Joel Sherrill | 2018-12-20 | 9 | -22/+22 |
* | eng: Unicode char (U+200B) | Sebastian Huber | 2018-12-20 | 1 | -3/+3 |
* | common/waf.py: Fix indentation. | Christian Mauderer | 2018-12-18 | 1 | -1/+1 |
| | | | | Python 3 produces an error if indentation is mixed tabs and spaces. | ||||
* | eng/coding-conventions.rst: Convert TBD to Rest Format (GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -2/+244 |
* | eng/coding-doxygen: Fix errors | Marçal Comajoan Cara | 2018-12-17 | 1 | -352/+360 |
| | | | | This work was part of GCI 2018. | ||||
* | eng/coding-file-hdr.rst: Fix file formatting (GCI 2018) | Sal | 2018-12-17 | 1 | -23/+25 |
* | eng/coding-doxygen.rst: Clean up and make subsubsections | Joel Sherrill | 2018-12-17 | 1 | -315/+362 |
* | Converted Doxygen Best Practices Documentation to Rest format (GCI 2018) | zehata | 2018-12-17 | 1 | -1/+417 |
* | coding-naming: Convert TBD to Rest format (GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -2/+85 |
* | images/eng/Git-personalrepo: Redrawn image (GCI 2018) | Marçal Comajoan Cara | 2018-12-17 | 2 | -0/+33 |
| | | | | | Redraw images/eng/Git-personalrepo as SVG and PNG with a better color palette. | ||||
* | eng/vc-users: Convert wiki page to Rest (GCI 2018) | Marçal Comajoan Cara | 2018-12-17 | 1 | -2/+641 |
| | | | | | | | | | Converted https://devel.rtems.org/wiki/Developer/Git/Users to Rest, and TBDs and wiki TODOs into comments. Also changed http links to https (the ones that are possible), corrected typos, updated learning resources links and added formattings. This work was part of GCI 2018. | ||||
* | eng/vc-authors: Convert wiki page to Rest (GCI 2018) | Marçal Comajoan Cara | 2018-12-17 | 2 | -2/+353 |
| | | | | | | | | | Converted https://devel.rtems.org/wiki/Developer/Git/Committers to Rest, and TBDs and wiki TODOs into comments. Also changed http links to https (the ones that are possible), corrected some typos, created a folder for eng images and added some formatting. This work was part of GCI 2018. | ||||
* | management: Convert TBD to rest Format (GCI 2018) | Pritiah Jain | 2018-12-17 | 2 | -2/+154 |
* | eng/conf.py: Use new short name of SW Eng Handbook | Marçal Comajoan Cara | 2018-12-17 | 1 | -1/+1 |
* | eng/license-requirements.rst: Add a TBD for BSD info | Joel Sherrill | 2018-12-17 | 1 | -0/+1 |
* | coding-doxygen-bsp.rst, coding-file-hdr.rst: Fix formatting | Joel Sherrill | 2018-12-17 | 2 | -321/+651 |
* | coding-file-hdr: Convert TBD to Rest Format (GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -3/+33 |
* | coding-doxygen-bsp: Convert TBD to rest Format(GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -4/+384 |
* | coding-gen-patch:Convert TBD to rest Format(GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -2/+27 |
* | eng/coding-80cols: Convert wiki page to Rest | Marçal Comajoan Cara | 2018-12-17 | 1 | -2/+146 |
| | | | | | | | Converted https://devel.rtems.org/wiki/Developer/Coding/80_characters_per_line to Rest, and TBDs into comments. This work was part of GCI 2018. | ||||
* | eng/appendix-a: convert to a table | Marçal Comajoan Cara | 2018-12-17 | 1 | -50/+106 |
| | | | | | | | Convert text to a table, TBDs into comments and add missing formatting. This work was part of GCI 2018. | ||||
* | eng/test-suites.rst: Update to reflect current reality | Joel Sherrill | 2018-12-17 | 1 | -6/+24 |
* | test-suites:Convert TBD to rest Format(GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -3/+32 |
* | Initial start of converting the Word outline to Rest | Joel Sherrill | 2018-12-17 | 31 | -0/+650 |
| | | | | | Thanks to Scott Zemerick <scott.zemerick@tmctechnologies.com> for the analysis and ideas that led to this. | ||||
* | Integrate images redrawn as part of GCI 2018 | Marçal Comajoan Cara | 2018-12-11 | 25 | -3/+817 |
| | | | | | | | All of the redrawings were made by me except images/c_user/states which was made by LukaMag. This patch serves to update all the images. This work was part of GCI 2018. | ||||
* | c-user: rtems_scheduler_get_maximum_priority() | Sebastian Huber | 2018-12-10 | 1 | -0/+37 |
| | | | | Close #3636. |
