* | cpu-supplement/sparc.rst: Fix me | Joel Sherrill | 2018-08-20 | 1 | -0/+593 |
* | cpu-supplement: Remove empty index | Sebastian Huber | 2018-08-20 | 2 | -6/+0 |
| | | | | | | | | Due to the hierarchical structure an index is not absolutely necessary and an empty index is not helpful. The document sources contain no index directives. Close #3499. | ||||
* | cpu-supplement: Remove empty command/vars chapter | Sebastian Huber | 2018-08-20 | 2 | -9/+0 |
| | | | | Close #3498. | ||||
* | c-user: SMP is supported on RISC-V | Sebastian Huber | 2018-08-11 | 1 | -1/+3 |
| | | | | Update #3433. | ||||
* | c-user: Adjust integer types in partition create | Sebastian Huber | 2018-08-10 | 1 | -2/+2 |
| | | | | Close #3486. | ||||
* | Fix SPARC_SWTRAP_IRQDIS typo | Joel Sherrill | 2018-08-09 | 1 | -1/+1 |
| | | | | close #3493. | ||||
* | c-user: CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE | Sebastian Huber | 2018-08-07 | 1 | -7/+37 |
| | | | | Close #3434. | ||||
* | c-user: Sort POSIX configuration options | Sebastian Huber | 2018-08-07 | 1 | -60/+60 |
* | c-user: Update partition create documentation | Sebastian Huber | 2018-08-03 | 1 | -11/+54 |
| | | | | | | Add an example. Close #3482. | ||||
* | user: Add RISC-V BSP section | Sebastian Huber | 2018-08-02 | 1 | -1/+109 |
* | cpu-supplement: Add RISC-V chapter | Sebastian Huber | 2018-08-02 | 2 | -0/+80 |
* | cpu-supplement: Update interrupt stack paragraph | Sebastian Huber | 2018-07-19 | 1 | -10/+14 |
| | | | | Close #3459. | ||||
* | user: Add x86_64 BSP chapter | Amaan Cheval | 2018-07-18 | 1 | -1/+142 |
* | bsp-howto: Mention clock driver hook removal | Sebastian Huber | 2018-06-26 | 1 | -22/+1 |
| | | | | Update #3436. | ||||
* | user: Add BSP chapter for each architecture | Sebastian Huber | 2018-06-26 | 19 | -0/+144 |
| | | | | Update #3464. | ||||
* | user: Add ARM BSPs chapter | Sebastian Huber | 2018-06-26 | 3 | -0/+153 |
| | | | | | | Add NXP i.MX section as a BSP example. Update #2854. | ||||
* | c-user: Document RTEMS_SYSINIT_CPU_COUNTER | Sebastian Huber | 2018-06-19 | 1 | -0/+6 |
| | | | | Update #3456. | ||||
* | c-user: Remove obsolete RTEMS_SYSINIT_CPU_SET | Sebastian Huber | 2018-06-18 | 1 | -4/+0 |
| | | | | Update #2514. | ||||
* | Adding Trace Documentation | Vidushi Vashishth | 2018-06-18 | 6 | -0/+996 |
| | | | | | | | | - Updates #3454 - This commit adds Tracing Framework Chapter in the RTEMS User Manual - It comprises of subchapters on RTEMS Trace Linker, Capture Engine, Trace generation techniques explaining trace generation using Trace Buffering and Printk generators and sample demonstrations. | ||||
* | Adding Trace Docuemntation Images | Vidushi Vashishth | 2018-06-18 | 2 | -0/+0 |
| | | | | -Removed CTF related images | ||||
* | c-user: RTEMS_FATAL_SOURCE_INVALID_HEAP_FREE | Sebastian Huber | 2018-06-05 | 1 | -0/+4 |
| | | | | Close #3437. | ||||
* | c-user: Update rtems_region_create() | Sebastian Huber | 2018-06-05 | 1 | -9/+10 |
* | configuring_a_system.rst, scheduling_concepts.rst: Fix spelling of arbitrary. | Joel Sherrill | 2018-05-23 | 2 | -2/+2 |
* | c-user: changed RTEMS_STATUS_SUCCESSFUL to RTEMS_SUCCESSFUL | Malte Münch | 2018-05-20 | 1 | -2/+2 |
* | c-user/configuring_a_system.rst: Removed double 'with' | Malte Münch | 2018-05-18 | 1 | -1/+1 |
* | fix typo: extesion->extension | Malte Münch | 2018-05-18 | 1 | -1/+1 |
* | c-user: Update manual organization in overview | Malte Münch | 2018-05-18 | 1 | -32/+57 |
* | c-user: Fix reference | Sebastian Huber | 2018-04-30 | 1 | -6/+6 |
* | c-user: Fix typo | Sebastian Huber | 2018-04-30 | 1 | -2/+2 |
* | Update due to BSP source reorganization | Sebastian Huber | 2018-04-27 | 14 | -356/+75 |
| | | | | | | This patch is a part of the BSP source reorganization. Close #3285. | ||||
* | bsp-howto: Avoid :file: role with ${...} | Sebastian Huber | 2018-04-23 | 1 | -4/+4 |
| | | | | | | | | The curly braces have a special meaning in the :file: role. This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | bsp-howto: Update BSP source code structure | Sebastian Huber | 2018-04-20 | 1 | -91/+41 |
* | user: Do not mention "bootstrap -p" | Sebastian Huber | 2018-03-28 | 1 | -2/+1 |
| | | | | | | It is now obsolete and was never necessary for an RTEMS users. Update #3254. | ||||
* | rsb: Add '--patchdir' option description | Maksim E. Kozlov | 2018-03-26 | 1 | -0/+7 |
| | | | | | | | According to commit d30be3129e9681a74efc80ce241aaf3c3a5b0efe in rtems-source-builder repo. Signed-off-by: Maksim E. Kozlov <maksim.e.kozlov@gmail.com> | ||||
* | c-user: Properly fix the previous typo | Sebastian Huber | 2018-03-12 | 1 | -1/+1 |
* | c-user: Fix typo | Sebastian Huber | 2018-03-12 | 1 | -1/+1 |
* | c-user: Simplify clustered scheduler configuration | Sebastian Huber | 2018-03-12 | 1 | -45/+54 |
| | | | | Close #3325. | ||||
* | Update the POSIX Compliance Tracking Spreadsheet. Add standards. | Joel Sherrill | 2018-03-09 | 6 | -1208/+1434 |
| | | | | | | | | | This update adds the following: C11 Programming Language Standard FACE Technical Standard Edition 3.0 (four profiles) Software Communication Architecture Specification 2.2.2 (one profile) Software Communication Architecture Specification 4.1 (three profiles) | ||||
* | RTEMS Docs: Check sphinx version | Richard Campbell | 2018-03-09 | 2 | -5/+23 |
| | | | | | | | Sphinx.util.compat module was removed at Sphinx version 1.7. Imported module was not being used. Closes #3311. | ||||
* | posix-compliance: Add description of standards | Joel Sherrill | 2018-03-09 | 3 | -5/+84 |
* | c-user: Fix simple SMP scheduler limits | Sebastian Huber | 2018-03-09 | 1 | -1/+1 |
* | c-user: Rework scheduler alogrithm config defs | Sebastian Huber | 2018-03-08 | 1 | -78/+92 |
| | | | | Update #3325. | ||||
* | c-user: Rework clustered scheduling configuration | Sebastian Huber | 2018-03-07 | 2 | -151/+185 |
* | c-user: Use uniprocessor throughout | Sebastian Huber | 2018-03-07 | 7 | -25/+25 |
* | c-user: Sort scheduler configuration options | Sebastian Huber | 2018-03-07 | 1 | -96/+96 |
* | c-user: Promote clustered scheduler configuration | Sebastian Huber | 2018-03-07 | 3 | -8/+7 |
| | | | | Add own section for the clustered scheduler configuration. | ||||
* | c-user: Fix scheduler configuration overview | Sebastian Huber | 2018-03-07 | 2 | -4/+6 |
* | c-user: Update CONFIGURE_SCHEDULER_NAME | Sebastian Huber | 2018-03-07 | 2 | -9/+27 |
* | CONFIGURE_*_SIMPLE_TASK_CONSOLE_DRIVER | Sebastian Huber | 2018-03-06 | 1 | -13/+84 |
| | | | | Update #3320. | ||||
* | CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER | Sebastian Huber | 2018-02-05 | 1 | -0/+39 |
| | | | | | Close #3170. Update #3199. |
