* | c-user: Correct copyright attribution to match original texinfo files | Joel Sherrill | 2016-11-08 | 2 | -4/+5 |
* | shell: Update commands to use descriptions. | Chris Johns | 2016-11-08 | 7 | -4488/+4303 |
* | waf: Get a copy of the optional packages. | Chris Johns | 2016-11-08 | 1 | -2/+2 |
* | waf: Use the good fonts if installed. | Chris Johns | 2016-11-08 | 5 | -22/+49 |
* | c-user: Format the directives as descriptions. | Chris Johns | 2016-11-08 | 30 | -8135/+7796 |
| | | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | ||||
* | pdf: Format lists for directives to sit on the next line. | Chris Johns | 2016-11-08 | 3 | -2/+7 |
* | Add openSUSE installation hints | Sebastian Huber | 2016-11-07 | 1 | -1/+14 |
* | PDF: Do not use lato and inconsolata fonts. Not widely supported. | Chris Johns | 2016-11-07 | 4 | -146/+5 |
* | waf: Add a program test for pygmentize. | Chris Johns | 2016-11-07 | 1 | -0/+3 |
* | README: Add packages for building on Arch. | Christian Mauderer | 2016-11-07 | 1 | -0/+12 |
* | waf: Fix ''NoneType' object is not iterable' | Christian Mauderer | 2016-11-07 | 1 | -4/+6 |
* | README: Update with more host specific details. | Chris Johns | 2016-11-06 | 1 | -18/+40 |
* | waf: Fix the host version check. | Chris Johns | 2016-11-06 | 1 | -3/+3 |
* | waf: Add support to handle missing Latex packages on hosts they are not ↵ | Chris Johns | 2016-11-06 | 11 | -95/+1113 |
| | | | | | | | | | | available on. It appears the support for texlive packages on some hosts is variable. This patch lets us add missing packages to our source tree so a PDF can be built on those hosts. The quality of the PDFs created may vary as some short cuts may have been take. For example lato is a font and only the sty file as been added and not the actual font which means it's use will default to another font. | ||||
* | waf: note about tex noise when running configure. | Chris Johns | 2016-11-04 | 1 | -0/+3 |
* | README: Add host set up for CentOS for singlehtml. | Chris Johns | 2016-11-04 | 1 | -0/+5 |
* | waf: Check for texlive packages and report an error is not found. | Chris Johns | 2016-11-04 | 2 | -9/+198 |
* | waf: Fix the bnode issue when building in a manual directory. | Chris Johns | 2016-11-04 | 1 | -1/+1 |
* | Update due to clock manager and driver changes | Sebastian Huber | 2016-11-03 | 7 | -109/+28 |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 139 | -11/+9 |
* | waf: Use separate doctrees so avoid sphinx clashes. | Chris Johns | 2016-11-03 | 1 | -10/+11 |
* | pdf: Make the copyright the same as the html. | Chris Johns | 2016-11-03 | 1 | -1/+1 |
* | conf: Make the build date use a nicer day format. | Chris Johns | 2016-11-03 | 1 | -1/+16 |
* | README: Add host set up and update the build commands. | Chris Johns | 2016-11-03 | 1 | -5/+38 |
* | waf: Have configure set building pdf and/or singlehtml. | Chris Johns | 2016-11-03 | 1 | -206/+247 |
| | | | | | | | | | | | | | | Move selecting pdf and singlehtml to the configure stage so it is sticky for all builds. This means a top level build will always build all formats that have been configured. Do not complete the configure stage if tools are missing for the configured output. Add singlehtml support using the inliner tool. It is nice. Remove the groups as waf can track the dependences. This lets the manuals build in parallel. | ||||
* | RSB: Fix the history. | Chris Johns | 2016-11-02 | 2 | -33/+9 |
* | Add a copyright to the PDF front page. | Chris Johns | 2016-11-02 | 2 | -3/+4 |
* | RSB: Fix the heading level for the PDF. | Chris Johns | 2016-11-02 | 10 | -100/+112 |
* | Update the top level README.txt. | Chris Johns | 2016-11-02 | 1 | -9/+19 |
* | Fix spelling. | Chris Johns | 2016-11-02 | 1 | -1/+1 |
* | RSB: Finish reformatting after moving from asciidocs. | Chris Johns | 2016-11-02 | 11 | -3504/+3534 |
* | html: Update the CSS and add topics. | Chris Johns | 2016-11-02 | 1 | -8/+30 |
* | waf: Fix the sphinx verbose option. | Chris Johns | 2016-11-02 | 1 | -2/+8 |
* | c_user: Re-add task notepads for 4.11. Remove this patch after branching. | Joel Sherrill | 2016-11-01 | 2 | -0/+146 |
* | Add some notes on writing documentation. | Chris Johns | 2016-11-01 | 1 | -0/+130 |
* | rsb: Fix the tex name. | Chris Johns | 2016-10-31 | 1 | -1/+1 |
* | Ignore waf files. | Chris Johns | 2016-10-31 | 1 | -0/+1 |
* | RSB: Clean up formatting and fix code-block mistakes. | Joel Sherrill | 2016-10-30 | 1 | -156/+173 |
* | waf: Add an install command. | Chris Johns | 2016-10-31 | 3 | -46/+77 |
* | RSB: Make the bullet style more consistent. | Joel Sherrill | 2016-10-30 | 2 | -34/+43 |
* | RSB: Initial addition | Joel Sherrill | 2016-10-30 | 5 | -0/+3621 |
| | | | | | | | | The content was manually converted from Asciidoc to Sphinx and there are some areas which remain to be done. Specifically there are some tables and embedded links which are known to remain but there are almost certainly other things to clean up. | ||||
* | waf: Add top build support. | Chris Johns | 2016-10-30 | 3 | -16/+248 |
* | waf: Add a build date to the copyright. | Chris Johns | 2016-10-30 | 1 | -1/+2 |
* | waf: Formatting. | Chris Johns | 2016-10-30 | 1 | -2/+2 |
* | porting: Review and tidy up multiple formatting issues. | Joel Sherrill | 2016-10-28 | 11 | -187/+223 |
* | filesystem: Fix numbered lists. | Joel Sherrill | 2016-10-28 | 1 | -39/+39 |
* | c_user: Fix numbered lists. | Joel Sherrill | 2016-10-28 | 2 | -5/+5 |
* | cpu_supplement: Fixed numbered list | Joel Sherrill | 2016-10-28 | 1 | -24/+24 |
* | in-memory.rst, mounting_and_unmounting.rst: Remove unnecessary backslash | Joel Sherrill | 2016-10-28 | 2 | -2/+2 |
* | user: Add comments about warnings we cannot remove. | Chris Johns | 2016-10-29 | 2 | -0/+5 |
