* | c-user: Add note to rtems_task_set_scheduler() | Sebastian Huber | 2017-03-08 | 1 | -1/+3 |
* | c-user: Update rtems_task_set_scheduler() | Sebastian Huber | 2017-03-07 | 1 | -31/+39 |
* | Add a check for Sphinx extensions. | Chris Johns | 2017-02-25 | 1 | -15/+44 |
| | | | | | | Minor clean up of the configure messages. Do not re-check sphinx in the nested configures. | ||||
* | Move extensions to common conf.py | Sebastian Huber | 2017-02-22 | 2 | -3/+2 |
* | Render math via JavaScript in HTML output | Sebastian Huber | 2017-02-20 | 2 | -4/+3 |
* | c-user: Fix linker set code blocks | Sebastian Huber | 2017-02-15 | 1 | -12/+13 |
* | c-user: Document linker set content | Sebastian Huber | 2017-02-15 | 1 | -0/+48 |
| | | | | Close #2770. | ||||
* | shell: Update task command | Sebastian Huber | 2017-02-14 | 1 | -3/+3 |
| | | | | Update #2858. | ||||
* | c-user: CONFIGURE_MAXIMUM_PROCESSORS | Sebastian Huber | 2017-02-14 | 3 | -44/+40 |
| | | | | Update #2894. | ||||
* | c-user: Add SMP internal locking | Sebastian Huber | 2017-02-03 | 1 | -0/+38 |
* | c-user: Add SMP profiling | Sebastian Huber | 2017-02-03 | 1 | -0/+58 |
* | c-user: Eliminate CONFIGURE_SMP_APPLICATION | Sebastian Huber | 2017-02-03 | 2 | -3/+2 |
| | | | | Update #2893. | ||||
* | c-user: Update SMP introduction | Sebastian Huber | 2017-02-03 | 3 | -50/+48 |
* | c-user: New SMP chapter title | Sebastian Huber | 2017-02-03 | 1 | -2/+2 |
* | c-user: Add TAS and TTAS terms | Sebastian Huber | 2017-02-03 | 2 | -2/+8 |
* | c-user: Update scheduler helping protocol | Sebastian Huber | 2017-02-03 | 1 | -68/+50 |
* | c-user: Add SMP low-level synchronization | Sebastian Huber | 2017-02-02 | 6 | -41/+93 |
* | c-user: Use sphinx glossary support | Sebastian Huber | 2017-02-02 | 2 | -658/+658 |
| | | | | Terms can be referenced via :term:`XYZ`. | ||||
* | c-user: Add SMP implementation details section | Sebastian Huber | 2017-02-02 | 1 | -38/+41 |
* | c-user: Add SMP application issues section | Sebastian Huber | 2017-02-02 | 3 | -151/+213 |
* | c-user: Update clustered scheduling | Sebastian Huber | 2017-02-02 | 2 | -28/+79 |
* | Update README due to use of math extension | Sebastian Huber | 2017-02-02 | 1 | -2/+3 |
* | Use "in X config..." instead of "on X config..." | Sebastian Huber | 2017-02-01 | 6 | -28/+27 |
* | c-user: Move scheduler directives | Sebastian Huber | 2017-02-01 | 2 | -166/+175 |
* | c-user: Remove duplicate thread queue section | Sebastian Huber | 2017-02-01 | 1 | -50/+0 |
* | c-user: Update task migration | Sebastian Huber | 2017-02-01 | 1 | -29/+9 |
* | c-user: Move some task directives | Sebastian Huber | 2017-02-01 | 2 | -237/+234 |
* | Do not show page references after internal links | Sebastian Huber | 2017-02-01 | 1 | -1/+1 |
* | Fix refs.bib entries | Sebastian Huber | 2017-02-01 | 1 | -1/+2 |
* | c-user: Add Key concept locking protocols | Sebastian Huber | 2017-02-01 | 3 | -85/+140 |
| | | | | | Update #2412. Update #2556. | ||||
* | c-user: Add key concept thread queues | Sebastian Huber | 2017-02-01 | 2 | -2/+70 |
* | Fix refs.bib entry | Sebastian Huber | 2017-01-31 | 2 | -2/+3 |
* | shell: Update task command | Sebastian Huber | 2017-01-31 | 1 | -4/+4 |
* | c-user: Task names | Sebastian Huber | 2017-01-31 | 2 | -1/+15 |
* | c-user: Update initialization | Sebastian Huber | 2017-01-30 | 1 | -4/+4 |
| | | | | Update #2692. | ||||
* | c-user: Update timer manager | Sebastian Huber | 2017-01-30 | 1 | -8/+16 |
| | | | | Update #2554. | ||||
* | c-user: Add timer and timeouts key concept | Sebastian Huber | 2017-01-30 | 3 | -1/+42 |
* | c-user: Update key concepts time | Sebastian Huber | 2017-01-30 | 2 | -11/+14 |
* | refs.bib: Add URL | Sebastian Huber | 2017-01-30 | 1 | -0/+1 |
* | c-user: Update overrun handling related functions and structure | Kuan-Hsun Chen | 2017-01-30 | 2 | -35/+89 |
| | | | | | | | | | State the limited count of postponed_jobs. Update _rtems_rate_monotonic_get_status() and related structure. Move "Further Reading" in c-user to references. Add mentioned papers in ticket #2795 to references. Update #2795. | ||||
* | c-user: Clarify rtems_heap_extend() | Sebastian Huber | 2017-01-27 | 1 | -9/+11 |
| | | | | Update #1747. | ||||
* | c-user: Region directives use the allocator mutex | Sebastian Huber | 2017-01-27 | 1 | -3/+12 |
* | c-user: Fix region directive prototypes | Sebastian Huber | 2017-01-27 | 1 | -26/+26 |
* | c-user: Rework user extensions chapter | Sebastian Huber | 2017-01-26 | 3 | -306/+286 |
| | | | | | Update #2692. Update #2752. | ||||
* | Fix some reference titles | Sebastian Huber | 2017-01-25 | 1 | -3/+3 |
* | Sort references | Sebastian Huber | 2017-01-25 | 1 | -108/+110 |
* | c-user: SMP thread dispatching | Sebastian Huber | 2017-01-24 | 1 | -57/+23 |
| | | | | Close #2809. | ||||
* | c-user: Clarify simple binary semaphore release | Sebastian Huber | 2017-01-23 | 1 | -9/+11 |
| | | | | Close #2725. | ||||
* | Mention sphinxcontrib-bibtex in README | Sebastian Huber | 2017-01-20 | 1 | -1/+3 |
* | c-user/ada_support.rst: Discuss timer server and interrupt threads | Joel Sherrill | 2017-01-19 | 1 | -0/+7 |
