* | c-user: Add key concept thread queues | Sebastian Huber | 2017-02-01 | 2 | -2/+70 | |
| | | | | Update #2556. | |||||
* | Fix refs.bib entry | Sebastian Huber | 2017-01-31 | 2 | -2/+3 | |
* | shell: Update task command | Sebastian Huber | 2017-01-31 | 1 | -4/+4 | |
| | | | | Update #2858. | |||||
* | c-user: Task names | Sebastian Huber | 2017-01-31 | 2 | -1/+15 | |
* | c-user: Update initialization | Sebastian Huber | 2017-01-30 | 1 | -4/+4 | |
| | | | | Update #2692. | |||||
* | c-user: Update timer manager | Sebastian Huber | 2017-01-30 | 1 | -8/+16 | |
| | | | | Update #2554. | |||||
* | c-user: Add timer and timeouts key concept | Sebastian Huber | 2017-01-30 | 3 | -1/+42 | |
* | c-user: Update key concepts time | Sebastian Huber | 2017-01-30 | 2 | -11/+14 | |
* | refs.bib: Add URL | Sebastian Huber | 2017-01-30 | 1 | -0/+1 | |
* | c-user: Update overrun handling related functions and structure | Kuan-Hsun Chen | 2017-01-30 | 2 | -35/+89 | |
| | | | | | | | | | State the limited count of postponed_jobs. Update _rtems_rate_monotonic_get_status() and related structure. Move "Further Reading" in c-user to references. Add mentioned papers in ticket #2795 to references. Update #2795. | |||||
* | c-user: Clarify rtems_heap_extend() | Sebastian Huber | 2017-01-27 | 1 | -9/+11 | |
| | | | | Update #1747. | |||||
* | c-user: Region directives use the allocator mutex | Sebastian Huber | 2017-01-27 | 1 | -3/+12 | |
* | c-user: Fix region directive prototypes | Sebastian Huber | 2017-01-27 | 1 | -26/+26 | |
* | c-user: Rework user extensions chapter | Sebastian Huber | 2017-01-26 | 3 | -306/+286 | |
| | | | | | Update #2692. Update #2752. | |||||
* | Fix some reference titles | Sebastian Huber | 2017-01-25 | 1 | -3/+3 | |
* | Sort references | Sebastian Huber | 2017-01-25 | 1 | -108/+110 | |
* | c-user: SMP thread dispatching | Sebastian Huber | 2017-01-24 | 1 | -57/+23 | |
| | | | | Close #2809. | |||||
* | c-user: Clarify simple binary semaphore release | Sebastian Huber | 2017-01-23 | 1 | -9/+11 | |
| | | | | Close #2725. | |||||
* | Mention sphinxcontrib-bibtex in README | Sebastian Huber | 2017-01-20 | 1 | -1/+3 | |
* | c-user/ada_support.rst: Discuss timer server and interrupt threads | Joel Sherrill | 2017-01-19 | 1 | -0/+7 | |
* | c-user: Add support for references via bibtex | Sebastian Huber | 2017-01-18 | 9 | -10/+196 | |
| | | | | | | https://sphinxcontrib-bibtex.readthedocs.io/en/latest/index.html Update #2871. | |||||
* | c-user: Add Ada support chapter | Joel Sherrill | 2017-01-17 | 2 | -0/+93 | |
| | | | | closes #2589. | |||||
* | c-user: Fix typo | Sebastian Huber | 2017-01-17 | 1 | -1/+1 | |
* | Update documentation to reflect EDF scheduler overrun handling | Kuan-Hsun Chen | 2017-01-13 | 1 | -12/+16 | |
* | Document CONFIGURE_MAXIMUM_THREAD_NAME_SIZE | Sebastian Huber | 2017-01-13 | 1 | -0/+31 | |
* | shell: Update cpuuse and stackuse sample output | Sebastian Huber | 2017-01-13 | 1 | -27/+87 | |
* | waf: Correct the branch version number. | Chris Johns | 2017-01-13 | 1 | -1/+1 | |
* | coverpage: Remove used function. | Chris Johns | 2017-01-12 | 1 | -15/+0 | |
* | coverpage: Make showing the table conditional. | Chris Johns | 2017-01-12 | 2 | -5/+5 | |
* | coverpage: Rename the static images directory to match bootstrap. | Chris Johns | 2017-01-12 | 3 | -2/+2 | |
* | coverpage: Fix the catalogue table id. | Chris Johns | 2017-01-12 | 1 | -1/+2 | |
* | coverpage: Update the coverpage to have the table collapse. | Chris Johns | 2017-01-12 | 14 | -20/+51 | |
| | | | | Add each doc's conf.py as a dependence to catalogue.xml. | |||||
* | conf.py: Fix build_date() to append correct suffix on all days. | Justin Powell | 2017-01-11 | 1 | -1/+7 | |
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 22 | -60/+60 | |
* | Remove references to SPARC/SIS BSP. Also clean up old ERC32 references. | Joel Sherrill | 2017-01-11 | 3 | -24/+7 | |
| | | | | updates #2810. | |||||
* | html: Embed the catalogue XML in JS. | Chris Johns | 2017-01-11 | 4 | -43/+81 | |
| | | | | | The is to work around a security issue with Chrome on Windows. This patches let the cover page load on Chrome and Edge on Windows 10. | |||||
* | html: Add support for an HTML cover page for releases. | Chris Johns | 2017-01-11 | 11 | -1/+279 | |
* | waf: Add a title to the XML Catalogue. | Chris Johns | 2017-01-10 | 2 | -9/+17 | |
* | waf: Improved XML Catalogue generator. | Chris Johns | 2017-01-10 | 2 | -49/+47 | |
* | waf: Create an XML Catalogue. | Chris Johns | 2017-01-09 | 2 | -0/+84 | |
* | waf: Update to waf-1.9.7 | Chris Johns | 2017-01-05 | 1 | -8/+8 | |
* | Update Console Driver chapter | Sebastian Huber | 2016-12-23 | 1 | -382/+346 | |
| | | | | | Close #2785. Close #2838. | |||||
* | Strip down BSP Introduction | Sebastian Huber | 2016-12-21 | 1 | -49/+13 | |
| | | | | Update #2852. | |||||
* | Add warnings to basic BSP chapters | Sebastian Huber | 2016-12-21 | 5 | -0/+20 | |
* | Move Shared Memory Support Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+1 | |
| | | | | | This chapter is very specific. Move it to a less prominent chapter position. | |||||
* | Move Ada95 Interrupt Support chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+1 | |
* | Add warning to Timer Driver chapter | Sebastian Huber | 2016-12-21 | 2 | -1/+6 | |
| | | | | | | Move Timer Driver chapter. Update #2847. | |||||
* | Add warning to ATA/IDE driver chapter | Sebastian Huber | 2016-12-21 | 3 | -2/+16 | |
| | | | | Close #2849. | |||||
* | Remove Non-Volatile Memory Driver chapter | Sebastian Huber | 2016-12-21 | 2 | -218/+0 | |
| | | | | | | | There exists no standard Non-Volatile Memory Driver in the RTEMS code base. Close #2851. | |||||
* | Remove Discrete Driver chapter | Sebastian Huber | 2016-12-21 | 2 | -191/+0 | |
| | | | | | | There exists no standard Discrete Driver in the RTEMS code base. Close #2851. |
