* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 139 | -11/+9 |
* | waf: Use separate doctrees so avoid sphinx clashes. | Chris Johns | 2016-11-03 | 1 | -10/+11 |
* | pdf: Make the copyright the same as the html. | Chris Johns | 2016-11-03 | 1 | -1/+1 |
* | conf: Make the build date use a nicer day format. | Chris Johns | 2016-11-03 | 1 | -1/+16 |
* | README: Add host set up and update the build commands. | Chris Johns | 2016-11-03 | 1 | -5/+38 |
* | waf: Have configure set building pdf and/or singlehtml. | Chris Johns | 2016-11-03 | 1 | -206/+247 |
| | | | | | | | | | | | | | | Move selecting pdf and singlehtml to the configure stage so it is sticky for all builds. This means a top level build will always build all formats that have been configured. Do not complete the configure stage if tools are missing for the configured output. Add singlehtml support using the inliner tool. It is nice. Remove the groups as waf can track the dependences. This lets the manuals build in parallel. | ||||
* | RSB: Fix the history. | Chris Johns | 2016-11-02 | 2 | -33/+9 |
* | Add a copyright to the PDF front page. | Chris Johns | 2016-11-02 | 2 | -3/+4 |
* | RSB: Fix the heading level for the PDF. | Chris Johns | 2016-11-02 | 10 | -100/+112 |
* | Update the top level README.txt. | Chris Johns | 2016-11-02 | 1 | -9/+19 |
* | Fix spelling. | Chris Johns | 2016-11-02 | 1 | -1/+1 |
* | RSB: Finish reformatting after moving from asciidocs. | Chris Johns | 2016-11-02 | 11 | -3504/+3534 |
* | html: Update the CSS and add topics. | Chris Johns | 2016-11-02 | 1 | -8/+30 |
* | waf: Fix the sphinx verbose option. | Chris Johns | 2016-11-02 | 1 | -2/+8 |
* | c_user: Re-add task notepads for 4.11. Remove this patch after branching. | Joel Sherrill | 2016-11-01 | 2 | -0/+146 |
* | Add some notes on writing documentation. | Chris Johns | 2016-11-01 | 1 | -0/+130 |
* | rsb: Fix the tex name. | Chris Johns | 2016-10-31 | 1 | -1/+1 |
* | Ignore waf files. | Chris Johns | 2016-10-31 | 1 | -0/+1 |
* | RSB: Clean up formatting and fix code-block mistakes. | Joel Sherrill | 2016-10-30 | 1 | -156/+173 |
* | waf: Add an install command. | Chris Johns | 2016-10-31 | 3 | -46/+77 |
* | RSB: Make the bullet style more consistent. | Joel Sherrill | 2016-10-30 | 2 | -34/+43 |
* | RSB: Initial addition | Joel Sherrill | 2016-10-30 | 5 | -0/+3621 |
| | | | | | | | | The content was manually converted from Asciidoc to Sphinx and there are some areas which remain to be done. Specifically there are some tables and embedded links which are known to remain but there are almost certainly other things to clean up. | ||||
* | waf: Add top build support. | Chris Johns | 2016-10-30 | 3 | -16/+248 |
* | waf: Add a build date to the copyright. | Chris Johns | 2016-10-30 | 1 | -1/+2 |
* | waf: Formatting. | Chris Johns | 2016-10-30 | 1 | -2/+2 |
* | porting: Review and tidy up multiple formatting issues. | Joel Sherrill | 2016-10-28 | 11 | -187/+223 |
* | filesystem: Fix numbered lists. | Joel Sherrill | 2016-10-28 | 1 | -39/+39 |
* | c_user: Fix numbered lists. | Joel Sherrill | 2016-10-28 | 2 | -5/+5 |
* | cpu_supplement: Fixed numbered list | Joel Sherrill | 2016-10-28 | 1 | -24/+24 |
* | in-memory.rst, mounting_and_unmounting.rst: Remove unnecessary backslash | Joel Sherrill | 2016-10-28 | 2 | -2/+2 |
* | user: Add comments about warnings we cannot remove. | Chris Johns | 2016-10-29 | 2 | -0/+5 |
* | user: Add comment to move to packages. | Chris Johns | 2016-10-29 | 1 | -0/+3 |
* | user: Add hardware layers figure. | Chris Johns | 2016-10-29 | 1 | -0/+0 |
* | powerpc, sparc, sparc64: Correct tables | Joel Sherrill | 2016-10-28 | 3 | -73/+57 |
* | Remove the old files. | Chris Johns | 2016-10-29 | 9 | -61699/+0 |
* | shell: Fix code-block warnings. | Chris Johns | 2016-10-29 | 5 | -294/+293 |
* | dec_21140.rst, network_task_structure.rst: Change image to figure | Joel Sherrill | 2016-10-28 | 2 | -6/+9 |
* | dec_21140.rst: Correct path to image | Joel Sherrill | 2016-10-28 | 1 | -1/+1 |
* | makefiles.rst, target_dependant_files.rst: Fix link | Joel Sherrill | 2016-10-28 | 2 | -1/+3 |
* | target_dependant_files.rst: Fix spacing and warning. | Joel Sherrill | 2016-10-28 | 1 | -1/+1 |
* | initilization_code.rst, linker_script.rst: Fix cross reference | Joel Sherrill | 2016-10-28 | 2 | -1/+3 |
* | waf: Update to support a recent waf. | Chris Johns | 2016-10-29 | 1 | -2/+2 |
* | object_services.rst: Add _rtems_object_id_api_minimum_class and ↵ | Joel Sherrill | 2016-10-28 | 2 | -1/+67 |
| | | | | _rtems_object_id_api_maximum_class | ||||
* | bsp_howto: Fix ASCII figure. | Chris Johns | 2016-10-28 | 1 | -11/+11 |
* | c_user: Remove errors and warnings. | Chris Johns | 2016-10-28 | 11 | -22/+338 |
* | Update the file list to the 4.11 directory structure. | Chris Johns | 2016-10-27 | 1 | -116/+3 |
* | Fix filesystem formatting. | Chris Johns | 2016-10-27 | 11 | -1404/+1165 |
* | porting: Fix code-block markup | Joel Sherrill | 2016-10-27 | 7 | -71/+71 |
* | bsp_howto: Fix code-block markup | Joel Sherrill | 2016-10-27 | 6 | -21/+21 |
* | rtems-docs: Fix many unnecessary back slashes | Joel Sherrill | 2016-10-27 | 15 | -96/+96 |
