* | Clarify INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL | Sebastian Huber | 2017-11-20 | 2 | -2/+6 |
| | | | | Update #3239. | ||||
* | c-user: Clarify rtems_interrupt_flash() | Sebastian Huber | 2017-11-20 | 1 | -7/+11 |
* | c-user: Remove clock driver specific functions | Sebastian Huber | 2017-11-17 | 1 | -3/+0 |
| | | | | | | Do not mention functions which belong to a specific clock driver implementation. These functions should not be called by applications directly. | ||||
* | Document INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL | Sebastian Huber | 2017-11-17 | 1 | -0/+4 |
| | | | | Close #3239. | ||||
* | INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT | Sebastian Huber | 2017-11-17 | 1 | -0/+4 |
* | bsp-howto: Add getentropy. | Christian Mauderer | 2017-11-17 | 2 | -0/+40 |
* | c-users: Clarify semaphore obtain/flush | Sebastian Huber | 2017-11-16 | 1 | -1/+43 |
* | bsp-howto/console: Move misplaced var. in example | Martin Erik Werner | 2017-11-16 | 1 | -1/+1 |
| | | | | Signed-off-by: Martin Erik Werner <martinerikwerner@gmail.com> | ||||
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 35 | -428/+708 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | Use '.. toctree::' and not '.. include::' in the User Manual. | Chris Johns | 2017-11-13 | 17 | -228/+30 |
| | | | | | | | | - Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232. | ||||
* | c-user: Fix index locations. | Chris Johns | 2017-11-12 | 36 | -785/+920 |
* | Add indexes to all documents. | Chris Johns | 2017-11-12 | 26 | -27/+65 |
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 16 | -272/+288 |
| | | | | Update #3220. | ||||
* | c-user/configuring_a_system.rst: Delete notepads section | Joel Sherrill | 2017-11-02 | 1 | -32/+0 |
| | | | | closes #3215. | ||||
* | posix-users: Clarify timed operation errors | Sebastian Huber | 2017-10-24 | 2 | -3/+7 |
| | | | | Close #3182. | ||||
* | posix-compliance: Latex does not like an empty glossary. | Chris Johns | 2017-10-13 | 1 | -0/+5 |
* | posix-compliance: Reference the generated content via the include file. | Chris Johns | 2017-10-13 | 5 | -7/+24 |
| | | | | | - Move the copyright to the top of the generated file. - Add a glossary and references section. | ||||
* | posix-compliance: Fix the pdflatex file created by Sphinx. | Chris Johns | 2017-10-12 | 1 | -1/+1 |
* | build: Remove the grouping in posix-compliance. | Chris Johns | 2017-10-12 | 1 | -1/+0 |
* | posix-compliance: Add automatic generation of the ReST file from CSV data. | Chris Johns | 2017-10-12 | 3 | -1/+291 |
| | | | | Closes #3177. | ||||
* | build: Add extra source to the sphinx build. | Chris Johns | 2017-10-12 | 1 | -11/+11 |
| | | | | Updates #3177. | ||||
* | New version of POSIX Compliance Guide | Joel Sherrill | 2017-10-12 | 32 | -7299/+1391 |
| | | | | | | | This is a replacement of the POSIX 1003.1 Compliance Guide. It will be generated from a .csv file. Updates #3177. | ||||
* | Shorten BSP and Driver Guide name (missed commit) | Joel Sherrill | 2017-10-12 | 1 | -1/+1 |
| | | | | Updates #3141. | ||||
* | Shorten the name of the BSP and Device Driver Development Guide | Joel Sherrill | 2017-10-12 | 5 | -17/+11 |
| | | | | | | | | | | | | | Old name: RTEMS BSP and Device Driver Development Guide This is long and causes problems in the PDF output. This patch changes the name to: RTEMS BSP and Driver Guide Closes #3141. | ||||
* | c-user: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES | Sebastian Huber | 2017-10-12 | 1 | -6/+30 |
| | | | | | | | This configuration is not obsolete since it is still used for named semaphores. Update #3116. | ||||
* | posix-users/thread.rst: Add pthread_getconcurrency and pthread_setconcurrency | Joel Sherrill | 2017-10-11 | 1 | -0/+69 |
| | | | | Closes #2680. | ||||
* | c-user: Update to reflect rtems_clock_get() being obsoleted. | Joel Sherrill | 2017-10-11 | 2 | -95/+22 |
| | | | | Closes #2693. | ||||
* | c-user: Add obsolete configuration options section | Sebastian Huber | 2017-10-09 | 1 | -164/+88 |
| | | | | | | | | | Update #2493. Update #3112. Update #3113. Update #3114. Update #3115. Update #3116. | ||||
* | c-user: Clarify that confdefs.h is mandatory | Sebastian Huber | 2017-10-06 | 1 | -21/+3 |
* | Mention i.MX 7 SMP support | Sebastian Huber | 2017-09-27 | 1 | -2/+7 |
| | | | | Update #3090. | ||||
* | bsp-howto: Clock_driver_support_install_isr() | Sebastian Huber | 2017-09-18 | 1 | -3/+5 |
| | | | | Close #3139. | ||||
* | Improve the line spaces for directives and notes. | Chris Johns | 2017-09-14 | 1 | -7/+20 |
* | c-user: Fix task create notes | Sebastian Huber | 2017-09-14 | 1 | -2/+6 |
* | c-user: Clarify SMP's rtems_get_processor_count. | Chris Johns | 2017-09-14 | 1 | -1/+4 |
* | Add PAX to the Ubuntu packages to install. | Chris Johns | 2017-09-04 | 1 | -1/+1 |
| | | | | Closes #3008. | ||||
* | Eclipse: Fix TOC and glossary licence comment. | Chris Johns | 2017-09-04 | 2 | -5/+1 |
* | common: Remove obsolete latex_use_parts | Sebastian Huber | 2017-08-25 | 1 | -4/+0 |
| | | | | | | | | This configuration is obsolete and no longer documented: http://www.sphinx-doc.org/en/stable/config.html#options-for-latex-output The use of parts at the top-level results in ugly documents. | ||||
* | cpu-supplement: Use literal instead of emphasis | Sebastian Huber | 2017-08-25 | 1 | -10/+11 |
| | | | | Update #3082. | ||||
* | cpu-supplement: Fix PowerPC TOC limitation | Sebastian Huber | 2017-08-24 | 1 | -2/+3 |
* | c-user: Clarify user extensions | Sebastian Huber | 2017-08-24 | 1 | -59/+66 |
| | | | | Close #2367. | ||||
* | cpu-supplement/powerpc: Rewrite | Sebastian Huber | 2017-08-23 | 1 | -475/+38 |
| | | | | | | | Remove obsolete and duplicated information. Reference the ABI specifications. Add 64-bit caveats. Update #3082. | ||||
* | coverpage: Fix repeated entries. | Chris Johns | 2017-08-11 | 2 | -2/+4 |
| | | | | Closes #2865. | ||||
* | Update copyright notices. | Chris Johns | 2017-08-11 | 15 | -83/+142 |
* | pdf: Update the RTEMS style to work recent Sphinx versions. | Chris Johns | 2017-08-11 | 1 | -54/+23 |
* | common/conf: Clean up. | Chris Johns | 2017-08-11 | 1 | -4/+0 |
* | Revert "Add the sphinxcontrib.bibtex extension to the repo." | Chris Johns | 2017-08-09 | 8 | -975/+1 |
| | | | | | | This reverts commit aa4f8e2e436d6c49e1524a4a3fb164b28632d894. The contrib has too many dependencies to add into the repo. | ||||
* | Add the sphinxcontrib.bibtex extension to the repo. | Chris Johns | 2017-08-07 | 8 | -1/+975 |
* | bsp: Optional clock driver shutdown | Sebastian Huber | 2017-08-04 | 1 | -4/+8 |
* | memory_management: update mmap, munmap, shm_open, shm_unlink | Gedare Bloom | 2017-07-28 | 1 | -9/+140 |
| | | | | Close #2859. | ||||
* | posix1003-1, posix_users: mark mmap and shm functions implemented | Gedare Bloom | 2017-07-28 | 3 | -24/+23 |
| | | | | Update #2859. |
