* | waf: Change --sphinx-verbose to --sphinx-options, add --sphinx-nit-pick | Chris Johns | 2019-02-28 | 2 | -17/+68 |
| | | | | | Provide options to manage sphinx. Make using the nit-picky mode simpler to access. | ||||
* | Add unicode support for commonly used characters like copyright. | Chris Johns | 2019-02-28 | 14 | -40/+71 |
| | | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals. | ||||
* | waf: Fix building the images in the src path. | Chris Johns | 2019-02-28 | 1 | -2/+1 |
* | waf: Fix python3 issues. | Chris Johns | 2019-02-28 | 2 | -8/+8 |
| | | | | - Found after updating to FreeBSD-12.0 which defaults to Python3. | ||||
* | Update User Documentation for Host setup for Linux | Vaibhav Gupta | 2019-02-28 | 2 | -0/+7 |
| | | | | | Mention the requirement of 'pax' package for building BSP if RTEMS is configured with '--enable-tests' option, else build fails. | ||||
* | user: Add a Dynamic Loader section. | Chris Johns | 2019-02-20 | 12 | -3/+962 |
* | c-user: INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA | Sebastian Huber | 2019-02-19 | 1 | -0/+5 |
| | | | | Update #3507. | ||||
* | user: Fix tense in quick start | Sebastian Huber | 2019-02-19 | 2 | -4/+5 |
* | user: Clarify U-Boot commands | Sebastian Huber | 2019-02-19 | 1 | -4/+12 |
* | user: Remove obsolete content in quick start | Sebastian Huber | 2019-02-18 | 1 | -87/+0 |
* | user: Add "Build Your Application" | Sebastian Huber | 2019-02-18 | 2 | -0/+12 |
* | user: Add "Test a Board Support Package (BSP)" | Sebastian Huber | 2019-02-18 | 3 | -0/+69 |
* | user: Add "Build a Board Support Package (BSP)" | Sebastian Huber | 2019-02-18 | 2 | -0/+147 |
* | user: Add "Bootstrap the RTEMS Sources" | Sebastian Huber | 2019-02-18 | 2 | -0/+56 |
* | user: Add "Install the Tool Suite" section | Sebastian Huber | 2019-02-18 | 3 | -0/+130 |
* | user: Add "Obtain the Sources" section | Sebastian Huber | 2019-02-18 | 2 | -0/+52 |
* | user: Rework Prefixes section | Sebastian Huber | 2019-02-18 | 5 | -41/+41 |
| | | | | | | Rename it to "Choose an Installation Prefix". Update #3675. | ||||
* | user: Fix references to prefixes section | Sebastian Huber | 2019-02-18 | 5 | -9/+7 |
* | user: Rework "Host Computer Setup" section | Sebastian Huber | 2019-02-18 | 2 | -10/+14 |
| | | | | Rename it to "Prepare Your Host Computer". | ||||
* | user: Add product name | Sebastian Huber | 2019-02-18 | 1 | -2/+2 |
* | user: Add basic Intel Cyclone V documentation | Sebastian Huber | 2019-02-18 | 1 | -2/+73 |
* | Use pathto() on the genindex URL to make it relative. | Chris Johns | 2019-02-15 | 15 | -32/+1 |
* | common/latex.py: Remove hack for CentOS. Use Texlive per instructions. | Joel Sherrill | 2019-02-13 | 1 | -8/+0 |
* | README.txt: Fix typos | Joel Sherrill | 2019-02-13 | 1 | -2/+2 |
* | waf: Use the release date in the coverpage | Chris Johns | 2019-02-14 | 2 | -4/+18 |
* | waf: Fix version.py to support older versions of git. | Chris Johns | 2019-02-13 | 2 | -17/+35 |
* | waf: Remove as many sys path hacks as we can. | Chris Johns | 2019-02-13 | 16 | -165/+111 |
| | | | | | | | | There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance. | ||||
* | Remove minted from the PDF builds. | Chris Johns | 2019-02-13 | 3 | -1518/+2 |
| | | | | | | This is feedback from the Sphinx project. See: https://github.com/sphinx-doc/sphinx/issues/6021#issuecomment-460951653 | ||||
* | Add copyright notices | Sebastian Huber | 2019-02-08 | 9 | -0/+13 |
* | build: Prepend project common path | Sebastian Huber | 2019-02-08 | 32 | -32/+32 |
| | | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library). | ||||
* | cpu-supplement: Fix file name | Sebastian Huber | 2019-02-07 | 2 | -1/+1 |
* | Version change, forgot to add wscript to the commit. | Chris Johns | 2019-02-07 | 1 | -1/+1 |
* | Fix the version logic to make it more robust. | Chris Johns | 2019-02-07 | 1 | -1/+4 |
* | Fix building with Sphinx 1.8 and later. | Chris Johns | 2019-02-06 | 2 | -14/+33 |
| | | | | | | | | - Provide the pytnon.ist file for makeindex. - Add support for xelatex building so we can switch if we want too. Closes #3669 | ||||
* | Support VERSION file for releasing and deployment | Chris Johns | 2019-02-06 | 2 | -35/+170 |
| | | | | - Shorten the GIT hash. | ||||
* | user: Add basic event recording documentation | Sebastian Huber | 2019-02-01 | 5 | -4/+64 |
| | | | | Update #3665. | ||||
* | c-user: Add event recording configuration | Sebastian Huber | 2019-02-01 | 1 | -0/+58 |
* | bsp-howto: Fix URLs | Sebastian Huber | 2019-01-31 | 2 | -2/+2 |
* | user: Use capital letters for acronyms | Sebastian Huber | 2019-01-24 | 2 | -4/+5 |
| | | | | Fix GCC definition. | ||||
* | user: Spell out third-party | Sebastian Huber | 2019-01-24 | 11 | -21/+21 |
* | user: Stub documentation for griscv BSP | Sebastian Huber | 2019-01-22 | 1 | -0/+6 |
| | | | | Update #3678. | ||||
* | Change first copyright year to 1988 | Sebastian Huber | 2019-01-18 | 1 | -1/+1 |
| | | | | The OAR copyright goes back to 1988. | ||||
* | user: Add "Host Computer Setup" to "Quick Start" | Sebastian Huber | 2019-01-14 | 2 | -0/+20 |
* | user: Move "Prefixes" to "Quick Start" | Sebastian Huber | 2019-01-14 | 4 | -42/+57 |
| | | | | | Move "Project Sandboxing" to a separate section of the "Installation" chapter since this is an advance topic which may confuse new users. | ||||
* | user: Rework "Hardware" chapter | Sebastian Huber | 2019-01-14 | 8 | -104/+120 |
| | | | | | | | Rename it to "Target Hardware". Remove BSPs section and reference the BSPs chapter instead. Remove explicit list of architectures and reference the BSPs chapter instead. Fix typos. Elaborate multilib description in the architecture section. | ||||
* | user: Move deployment details to RSB chapter | Sebastian Huber | 2019-01-14 | 3 | -155/+164 |
* | user: Move "Ecosystem" into "Introduction" | Sebastian Huber | 2019-01-14 | 3 | -242/+239 |
* | user: Move "Support" to "Introduction" | Sebastian Huber | 2019-01-14 | 3 | -128/+125 |
| | | | | | New users may find it useful to get this information in the introduction. | ||||
* | Reformat and update copyright and license notices | Sebastian Huber | 2019-01-14 | 14 | -99/+90 |
| | | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | ||||
* | user: Add RSB content as a chapter | Sebastian Huber | 2019-01-14 | 14 | -81/+33 |
| | | | | Remove the separate RSB manual. |
