* | user: Rework overview | Sebastian Huber | 2019-01-09 | 3 | -31/+233 |
| | | | | | | Move "Overview", "Real-time Applicaiton Systems" and "Real-time Executive" chapters as sections into new "Introduction" chapter. Add "Feature" section. | ||||
* | Update header.rst | Sebastian Huber | 2019-01-09 | 1 | -10/+10 |
| | | | | Remove trailing slashes in URLs. Fix bug reporting URL. | ||||
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 15 | -322/+37 |
* | Remove superfluous word "Copyright" | Sebastian Huber | 2019-01-09 | 1 | -1/+1 |
| | | | | The © symbol is sufficient. | ||||
* | Update general copyright notice | Sebastian Huber | 2019-01-09 | 1 | -1/+1 |
| | | | | Update year and add "and contributors". | ||||
* | Replace build date with Git hash and commit date | Sebastian Huber | 2019-01-09 | 3 | -47/+39 |
| | | | | The usage of a build date prevents reproducible builds. | ||||
* | cpu-supplement: Update ARM multilibs | Sebastian Huber | 2019-01-07 | 1 | -7/+18 |
* | c-user: Fix typos | Frédéric Jouault | 2019-01-04 | 2 | -4/+4 |
| | | | | Close #3261. | ||||
* | sparc_v8_stacks_regwin.rst: Add middle initail for Peter Magnusson | Joel Sherrill | 2018-12-20 | 1 | -2/+2 |
| | | | | | | Peter requested this after reviewing the converted content. He noted that it was a nit but he had consistently used his middle initial in all academic settings and wanted to be consistent. | ||||
* | Eliminate UTF-8 characters except superscripted 2 in i2c | Joel Sherrill | 2018-12-20 | 9 | -22/+22 |
* | eng: Unicode char (U+200B) | Sebastian Huber | 2018-12-20 | 1 | -3/+3 |
* | common/waf.py: Fix indentation. | Christian Mauderer | 2018-12-18 | 1 | -1/+1 |
| | | | | Python 3 produces an error if indentation is mixed tabs and spaces. | ||||
* | eng/coding-conventions.rst: Convert TBD to Rest Format (GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -2/+244 |
* | eng/coding-doxygen: Fix errors | Marçal Comajoan Cara | 2018-12-17 | 1 | -352/+360 |
| | | | | This work was part of GCI 2018. | ||||
* | eng/coding-file-hdr.rst: Fix file formatting (GCI 2018) | Sal | 2018-12-17 | 1 | -23/+25 |
* | eng/coding-doxygen.rst: Clean up and make subsubsections | Joel Sherrill | 2018-12-17 | 1 | -315/+362 |
* | Converted Doxygen Best Practices Documentation to Rest format (GCI 2018) | zehata | 2018-12-17 | 1 | -1/+417 |
* | coding-naming: Convert TBD to Rest format (GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -2/+85 |
* | images/eng/Git-personalrepo: Redrawn image (GCI 2018) | Marçal Comajoan Cara | 2018-12-17 | 2 | -0/+33 |
| | | | | | Redraw images/eng/Git-personalrepo as SVG and PNG with a better color palette. | ||||
* | eng/vc-users: Convert wiki page to Rest (GCI 2018) | Marçal Comajoan Cara | 2018-12-17 | 1 | -2/+641 |
| | | | | | | | | | Converted https://devel.rtems.org/wiki/Developer/Git/Users to Rest, and TBDs and wiki TODOs into comments. Also changed http links to https (the ones that are possible), corrected typos, updated learning resources links and added formattings. This work was part of GCI 2018. | ||||
* | eng/vc-authors: Convert wiki page to Rest (GCI 2018) | Marçal Comajoan Cara | 2018-12-17 | 2 | -2/+353 |
| | | | | | | | | | Converted https://devel.rtems.org/wiki/Developer/Git/Committers to Rest, and TBDs and wiki TODOs into comments. Also changed http links to https (the ones that are possible), corrected some typos, created a folder for eng images and added some formatting. This work was part of GCI 2018. | ||||
* | management: Convert TBD to rest Format (GCI 2018) | Pritiah Jain | 2018-12-17 | 2 | -2/+154 |
* | eng/conf.py: Use new short name of SW Eng Handbook | Marçal Comajoan Cara | 2018-12-17 | 1 | -1/+1 |
* | eng/license-requirements.rst: Add a TBD for BSD info | Joel Sherrill | 2018-12-17 | 1 | -0/+1 |
* | coding-doxygen-bsp.rst, coding-file-hdr.rst: Fix formatting | Joel Sherrill | 2018-12-17 | 2 | -321/+651 |
* | coding-file-hdr: Convert TBD to Rest Format (GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -3/+33 |
* | coding-doxygen-bsp: Convert TBD to rest Format(GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -4/+384 |
* | coding-gen-patch:Convert TBD to rest Format(GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -2/+27 |
* | eng/coding-80cols: Convert wiki page to Rest | Marçal Comajoan Cara | 2018-12-17 | 1 | -2/+146 |
| | | | | | | | Converted https://devel.rtems.org/wiki/Developer/Coding/80_characters_per_line to Rest, and TBDs into comments. This work was part of GCI 2018. | ||||
* | eng/appendix-a: convert to a table | Marçal Comajoan Cara | 2018-12-17 | 1 | -50/+106 |
| | | | | | | | Convert text to a table, TBDs into comments and add missing formatting. This work was part of GCI 2018. | ||||
* | eng/test-suites.rst: Update to reflect current reality | Joel Sherrill | 2018-12-17 | 1 | -6/+24 |
* | test-suites:Convert TBD to rest Format(GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -3/+32 |
* | Initial start of converting the Word outline to Rest | Joel Sherrill | 2018-12-17 | 31 | -0/+650 |
| | | | | | Thanks to Scott Zemerick <scott.zemerick@tmctechnologies.com> for the analysis and ideas that led to this. | ||||
* | Integrate images redrawn as part of GCI 2018 | Marçal Comajoan Cara | 2018-12-11 | 25 | -3/+817 |
| | | | | | | | All of the redrawings were made by me except images/c_user/states which was made by LukaMag. This patch serves to update all the images. This work was part of GCI 2018. | ||||
* | c-user: rtems_scheduler_get_maximum_priority() | Sebastian Huber | 2018-12-10 | 1 | -0/+37 |
| | | | | Close #3636. | ||||
* | posix-compliance: Change utimes() from sys/times.h to sys/time.h | Marçal Comajoan Cara | 2018-12-09 | 2 | -8/+8 |
| | | | | | | | | | | | | | | | | | | | In the RTEMS POSIX 1003.1 Compliance Guide it says: The following methods and variables in <sys/times.h> are supported: - times() - utimes() But according to the official POSIX Specifications http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/sys_times.h.html, <sys/times.h> only declares times(), and utimes() is decleared by <sys/time.h> (notice that it's time, not times) according to http://pubs.opengroup.org/onlinepubs/9699919799/functions/utimensat.html and http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/sys_time.h.html. This patch fixes this error. This work was part of GCI 2018. | ||||
* | Fix error messages when Sphinx version cannot be checked. | Amar Takhar | 2018-12-05 | 1 | -2/+2 |
| | | | | | | | | | | This is kind of a dual-check since it checks for the version while simultaneously checking to see if Sphinx exists on the system. Changed the error messages to be clear on the error and removed a reference to version which cannot be set due to the check failure. Reported by: Shashvat Jain | ||||
* | posix-users/input_and_output.rst: Document errors for mount() and unmount() | Joel Sherrill | 2018-11-21 | 1 | -4/+15 |
* | posix-users/device_and_class_specific.rst: Add Prototypes | Marçal Comajoan Cara | 2018-11-21 | 1 | -20/+28 |
| | | | | | | | Add and update Device and Class Specific APIs in POSIX Users Guide. This work was part of GCI 2018. | ||||
* | posix-users/input_and_output.rst: Add Prototypes | Marçal Comajoan Cara | 2018-11-21 | 1 | -28/+56 |
| | | | | | | | Add and update Prototypes to Input and Output APIs in POSIX Users Guide. This work was part of GCI 2018. | ||||
* | posix-users/memory_managment.rst: Add Prototypes | Marçal Comajoan Cara | 2018-11-21 | 1 | -0/+22 |
| | | | | | | Add Prototypes to Memory Management APIs in POSIX Users Guide. This work was part of GCI 2018. | ||||
* | posix-users/system_database.rst: Add Prototypes | Marçal Comajoan Cara | 2018-11-21 | 1 | -4/+36 |
| | | | | | | Add Prototypes to System Database APIs in POSIX Users Guide. This work was part of GCI 2018. | ||||
* | posix-users/thread_cancellation.rst: Add Prototypes | Marçal Comajoan Cara | 2018-11-21 | 1 | -3/+18 |
| | | | | | | Add Prototypes to Thread Cancellation APIs. This work was part of GCI 2018. | ||||
* | posix-users/language_specific_services.rst: Add Prototypes to Language ↵ | Marçal Comajoan Cara | 2018-11-21 | 1 | -42/+48 |
| | | | | | | Specific Service APIs This work was part of GCI 2018. | ||||
* | c-user: Remove 16-bit object identifiers | Sebastian Huber | 2018-11-21 | 1 | -36/+8 |
| | | | | Close #3603. | ||||
* | cpu-supplement/sparc.rst: Merge Annul Slot Explanation (GCI 2018) | zehata | 2018-11-20 | 1 | -0/+45 |
| | | | | | This content originated as an email response from Jiri Gaisler to Joel Sherrill in response to a question. | ||||
* | cpu-supplement/sparc_v8_stacks_regwin.rst: Add credit box | Joel Sherrill | 2018-11-20 | 1 | -0/+8 |
* | cpu-supplement/sparc_v8_stacks_regwin.rst: Complete Formatting | Marçal Comajoan Cara | 2018-11-20 | 1 | -49/+48 |
* | images/cpu_supplement/sparcwin.svg: New file (GCI 2018) | Marçal Comajoan Cara | 2018-11-19 | 1 | -0/+176 |
| | | | | File was missed in previous commit. | ||||
* | cpu-supplement/sparc_v8_stacks_regwin.rst: Simplify section title | Joel Sherrill | 2018-11-19 | 1 | -2/+2 |
