If only one constraint is present, then use a single sentence, otherwise
use a list for the constraints. Format the constraints so that the line
length limit is maintained.
Replace copy and paste with a proper description.
Update #3715.
Use links instead of this special purpose attributes.
Update #3715.
Update #3715.
Update #3715.
The documentation is a consolidation of the comments in Doxygen markup
and the documentation sources in Sphinx markup. The documentation was
transfered to interface specification items. The documentation source
files were generated from the items by a script.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #4392.
Update #3715.
Update #3993.
Update #3993.
The new i2c driver in the beagle BSP uses FDT based initialization.
This updates the documentation of the BSP about the same.
A timer may be also reinitiated by the timer server fire directives.
Update #4267.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
This makes it easier to automatically generate parts of the module
documentation in the future.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Add glossary terms which characterize the relationship of a scheduler to
a task.
README-cvs.txt will need to be updated each time the spreadsheet is updated.
The spreadsheet is managed and maintained externally and has a version in
the name. We do not want that in the repository because a diff of the CSV
should always be much smaller than a "delete old/add new" patch.
The new version of the API tracking spreadsheet includes FACE
Technical Standard, Edition 3.1 as well as a few additions to
what RTEMS supports. The generation script and discussion of
standards was updated to reflect the inclusion of a new Edition
of the FACE Technical Standard.
Closes #4380.
The directive returns RTEMS_UNSATISFIED if the semaphore's count already
had the maximum value of UINT32_MAX.
Update #4372
Update #3715.
