* | user: Document QorIQ BSP variants | Sebastian Huber | 2018-10-01 | 1 | -0/+3 |
* | rsb/hosts.rst: Add more packages needed on Ubuntu | Joel Sherrill | 2018-09-25 | 1 | -2/+2 |
| | | | | Closes #3517. | ||||
* | RSB: Fix MacOS typos | Joel Sherrill | 2018-09-25 | 1 | -3/+3 |
| | | | | Close #3518. | ||||
* | user: Add i.MX 7D MMC/SDCard driver | Sebastian Huber | 2018-09-25 | 1 | -0/+8 |
| | | | | Close #3525. | ||||
* | Remove CONFIGURE_HAS_OWN_CONFIGURATION_TABLE | Sebastian Huber | 2018-09-17 | 1 | -26/+7 |
| | | | | | Close #3489. Close #3490. | ||||
* | c-user: Remove CONFIGURE_HAS_OWN_MOUNT_TABLE | Sebastian Huber | 2018-09-17 | 1 | -33/+7 |
| | | | | Close #3488. | ||||
* | c-user: Mention thread pinning | Sebastian Huber | 2018-09-10 | 1 | -0/+22 |
| | | | | Close #3508. | ||||
* | c-user: Mention per-processor data | Sebastian Huber | 2018-09-10 | 1 | -0/+18 |
| | | | | Close #3507. | ||||
* | user: Add qoriq BSP section | Sebastian Huber | 2018-08-29 | 1 | -1/+78 |
| | | | | Update #2854. | ||||
* | waf: Fix type in single html build. | Chris Johns | 2018-08-21 | 1 | -1/+1 |
* | pdf: Revert the changes to the Latex index formatting. | Chris Johns | 2018-08-21 | 2 | -1/+4 |
| | | | | | I removed the '_' splitting of long labels from the index when testing and this puts it back. | ||||
* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 30 | -103/+71 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | cpu-supplement/sparc.rst: Revert work in progress accidentally committed | Joel Sherrill | 2018-08-20 | 1 | -593/+0 |
* | user: Update x86-64 chapter with end-of-GSoC status | Amaan Cheval | 2018-08-20 | 1 | -1/+51 |
* | cpu-supplement/sparc.rst: Fix me | Joel Sherrill | 2018-08-20 | 1 | -0/+593 |
* | cpu-supplement: Remove empty index | Sebastian Huber | 2018-08-20 | 2 | -6/+0 |
| | | | | | | | | Due to the hierarchical structure an index is not absolutely necessary and an empty index is not helpful. The document sources contain no index directives. Close #3499. | ||||
* | cpu-supplement: Remove empty command/vars chapter | Sebastian Huber | 2018-08-20 | 2 | -9/+0 |
| | | | | Close #3498. | ||||
* | c-user: SMP is supported on RISC-V | Sebastian Huber | 2018-08-11 | 1 | -1/+3 |
| | | | | Update #3433. | ||||
* | c-user: Adjust integer types in partition create | Sebastian Huber | 2018-08-10 | 1 | -2/+2 |
| | | | | Close #3486. | ||||
* | Fix SPARC_SWTRAP_IRQDIS typo | Joel Sherrill | 2018-08-09 | 1 | -1/+1 |
| | | | | close #3493. | ||||
* | c-user: CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE | Sebastian Huber | 2018-08-07 | 1 | -7/+37 |
| | | | | Close #3434. | ||||
* | c-user: Sort POSIX configuration options | Sebastian Huber | 2018-08-07 | 1 | -60/+60 |
* | c-user: Update partition create documentation | Sebastian Huber | 2018-08-03 | 1 | -11/+54 |
| | | | | | | Add an example. Close #3482. | ||||
* | user: Add RISC-V BSP section | Sebastian Huber | 2018-08-02 | 1 | -1/+109 |
* | cpu-supplement: Add RISC-V chapter | Sebastian Huber | 2018-08-02 | 2 | -0/+80 |
* | cpu-supplement: Update interrupt stack paragraph | Sebastian Huber | 2018-07-19 | 1 | -10/+14 |
| | | | | Close #3459. | ||||
* | user: Add x86_64 BSP chapter | Amaan Cheval | 2018-07-18 | 1 | -1/+142 |
* | bsp-howto: Mention clock driver hook removal | Sebastian Huber | 2018-06-26 | 1 | -22/+1 |
| | | | | Update #3436. | ||||
* | user: Add BSP chapter for each architecture | Sebastian Huber | 2018-06-26 | 19 | -0/+144 |
| | | | | Update #3464. | ||||
* | user: Add ARM BSPs chapter | Sebastian Huber | 2018-06-26 | 3 | -0/+153 |
| | | | | | | Add NXP i.MX section as a BSP example. Update #2854. | ||||
* | c-user: Document RTEMS_SYSINIT_CPU_COUNTER | Sebastian Huber | 2018-06-19 | 1 | -0/+6 |
| | | | | Update #3456. | ||||
* | c-user: Remove obsolete RTEMS_SYSINIT_CPU_SET | Sebastian Huber | 2018-06-18 | 1 | -4/+0 |
| | | | | Update #2514. | ||||
* | Adding Trace Documentation | Vidushi Vashishth | 2018-06-18 | 6 | -0/+996 |
| | | | | | | | | - Updates #3454 - This commit adds Tracing Framework Chapter in the RTEMS User Manual - It comprises of subchapters on RTEMS Trace Linker, Capture Engine, Trace generation techniques explaining trace generation using Trace Buffering and Printk generators and sample demonstrations. | ||||
* | Adding Trace Docuemntation Images | Vidushi Vashishth | 2018-06-18 | 2 | -0/+0 |
| | | | | -Removed CTF related images | ||||
* | c-user: RTEMS_FATAL_SOURCE_INVALID_HEAP_FREE | Sebastian Huber | 2018-06-05 | 1 | -0/+4 |
| | | | | Close #3437. | ||||
* | c-user: Update rtems_region_create() | Sebastian Huber | 2018-06-05 | 1 | -9/+10 |
* | configuring_a_system.rst, scheduling_concepts.rst: Fix spelling of arbitrary. | Joel Sherrill | 2018-05-23 | 2 | -2/+2 |
* | c-user: changed RTEMS_STATUS_SUCCESSFUL to RTEMS_SUCCESSFUL | Malte Münch | 2018-05-20 | 1 | -2/+2 |
* | c-user/configuring_a_system.rst: Removed double 'with' | Malte Münch | 2018-05-18 | 1 | -1/+1 |
* | fix typo: extesion->extension | Malte Münch | 2018-05-18 | 1 | -1/+1 |
* | c-user: Update manual organization in overview | Malte Münch | 2018-05-18 | 1 | -32/+57 |
* | c-user: Fix reference | Sebastian Huber | 2018-04-30 | 1 | -6/+6 |
* | c-user: Fix typo | Sebastian Huber | 2018-04-30 | 1 | -2/+2 |
* | Update due to BSP source reorganization | Sebastian Huber | 2018-04-27 | 14 | -356/+75 |
| | | | | | | This patch is a part of the BSP source reorganization. Close #3285. | ||||
* | bsp-howto: Avoid :file: role with ${...} | Sebastian Huber | 2018-04-23 | 1 | -4/+4 |
| | | | | | | | | The curly braces have a special meaning in the :file: role. This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | bsp-howto: Update BSP source code structure | Sebastian Huber | 2018-04-20 | 1 | -91/+41 |
* | user: Do not mention "bootstrap -p" | Sebastian Huber | 2018-03-28 | 1 | -2/+1 |
| | | | | | | It is now obsolete and was never necessary for an RTEMS users. Update #3254. | ||||
* | rsb: Add '--patchdir' option description | Maksim E. Kozlov | 2018-03-26 | 1 | -0/+7 |
| | | | | | | | According to commit d30be3129e9681a74efc80ce241aaf3c3a5b0efe in rtems-source-builder repo. Signed-off-by: Maksim E. Kozlov <maksim.e.kozlov@gmail.com> | ||||
* | c-user: Properly fix the previous typo | Sebastian Huber | 2018-03-12 | 1 | -1/+1 |
* | c-user: Fix typo | Sebastian Huber | 2018-03-12 | 1 | -1/+1 |
