* | Rework RTEMS licensing discussions. | Joel Sherrill | 2020-05-01 | 2 | -14/+96 |
| | | | | | | | This now captures historical rationale along with cross-linking code templates with license guidelines. Closes #3962. | ||||
* | user/rsb: Update the configuration documentation | Chris Johns | 2020-04-28 | 1 | -39/+13 |
| | | | | Closes #3945 | ||||
* | user/tester: Remove command line help as output | Chris Johns | 2020-04-28 | 1 | -31/+2 |
| | | | | Closes #3381 | ||||
* | user: Update the RSB BSP quick start to say where the tests are installed | Chris Johns | 2020-04-28 | 1 | -1/+3 |
| | | | | Closes #3956 | ||||
* | freebsd: Update to reflect the current release 12 requirements | Chris Johns | 2020-04-27 | 1 | -13/+14 |
| | | | | Closes #3960 | ||||
* | c-user: Document rtems_extension_create() | Sebastian Huber | 2020-04-17 | 1 | -0/+2 |
| | | | | Close #3953. | ||||
* | user/imx: Add i.MX6UL/ULL. | Christian Mauderer | 2020-04-15 | 1 | -3/+44 |
| | | | | Update #3869 | ||||
* | c-user: Fix RTEMS_SCHEDULER_EDF_SMP() | Sebastian Huber | 2020-04-15 | 1 | -1/+1 |
| | | | | Update #3815. | ||||
* | eng: Adjust config.h include | Sebastian Huber | 2020-04-15 | 1 | -1/+1 |
| | | | | Use variant used by most source files. | ||||
* | c-user: Split deprecated/removed directives chapter | Sebastian Huber | 2020-04-15 | 1 | -4/+7 |
* | c-user: Add removed directive rtems_clock_get() | Sebastian Huber | 2020-04-15 | 1 | -21/+108 |
| | | | | | | Be in line with Task Manager chapter. Update #2693. | ||||
* | user: Update migration guide | Sebastian Huber | 2020-04-15 | 1 | -12/+44 |
| | | | | Update #3895. | ||||
* | user: Fix start app chmod execute of waf. | Chris Johns | 2020-04-14 | 1 | -1/+1 |
* | user: Document event recording | Sebastian Huber | 2020-04-11 | 1 | -10/+212 |
| | | | | Close #3904. | ||||
* | user/tools/tester.rst: Removes text references to 'erc32-run' and replaces ↵ | Cláudio Maia | 2020-04-09 | 1 | -5/+3 |
| | | | | the example with 'erc32-sis' | ||||
* | user/tools/tester.rst: Removes example using 'sparc-rtems5-run' | Cláudio Maia | 2020-04-09 | 1 | -13/+1 |
* | user/tools/tester.rst: Clarifies the need of --rtems-tools in rtems-test ↵ | Cláudio Maia | 2020-04-09 | 1 | -6/+8 |
| | | | | command line | ||||
* | user/tools/tester.rst: Removes wrong reference to GDB | Cláudio Maia | 2020-04-09 | 1 | -3/+0 |
* | user/tools/tester.rst: Cleans up text | Cláudio Maia | 2020-04-09 | 1 | -80/+90 |
* | rsb/configuration: add my copyright | Gedare Bloom | 2020-04-05 | 1 | -0/+1 |
* | user/rsb: describe how to create configuration reports | Gedare Bloom | 2020-04-05 | 1 | -3/+18 |
| | | | | Closes #3629. | ||||
* | rsb: replace asciidoc with rst formatting | Gedare Bloom | 2020-04-05 | 2 | -10/+10 |
* | user/rsb/configuration: fix typo xy to xz | Gedare Bloom | 2020-04-05 | 1 | -2/+2 |
* | rsb/configuration: fix broken link to _configdir | Gedare Bloom | 2020-04-05 | 1 | -2/+3 |
* | user: update copyright and minor typo | Gedare Bloom | 2020-04-04 | 2 | -2/+3 |
* | Chapter-on-need-for-RTEMS-specific-cross-compiler | Utkarsh Rai | 2020-04-04 | 1 | -0/+33 |
| | | | | Removed '-' character and provided definition list format | ||||
* | common: fix title page | Gedare Bloom | 2020-04-04 | 2 | -1/+2 |
| | | | | | Sphinx changed the default behavior of maketitle. Provide our own rtemsmaketitle command and use it instead. | ||||
* | Add a release procedure section. | Chris Johns | 2020-04-04 | 2 | -3/+271 |
* | Update top-level copyrights | Gedare Bloom | 2020-04-03 | 1 | -1/+2 |
* | RTEMS Docs: Add steps for sphinxcontrib-bibtex | Vaibhav Gupta | 2020-04-03 | 1 | -0/+1 |
| | | | | | | | | Add step to install sphinxcontrib-bibtex together with the steps mentioned for ArcLinux, to install sphinx and dependencies. Signed-off-by: Vaibhav Gupta <vaibhavgupta40@gmail.com> | ||||
* | waf: User friendly message when no sphinx is installed | Chris Johns | 2020-04-03 | 1 | -0/+3 |
* | Add virtualenv to the README.txt as the preferred host support. | Chris Johns | 2020-04-03 | 1 | -1/+21 |
* | doc: Moving M68K BSP Content to User Manual (#3905) | Mritunjay | 2020-04-03 | 1 | -2/+188 |
| | | | | Fixed trailing spaces. | ||||
* | user/start/gsoc: fix unicode error and grammar typo | Gedare Bloom | 2020-04-02 | 1 | -2/+2 |
* | start/index: relocate gsoc section | Gedare Bloom | 2020-04-02 | 1 | -1/+1 |
* | start/gsoc: GSoC Getting started instructions. | G S Niteesh Babu | 2020-04-02 | 3 | -0/+134 |
| | | | | | Added instructions to setup development environment for students interested in GSoC. | ||||
* | user/bsp-build: Fix broken cross references. | G S Niteesh Babu | 2020-04-02 | 1 | -2/+2 |
| | | | | | | The QuickStartBSPBuild_Manual and QuickStartBSPBuild_RSB are missing the underscore in front. This breaks any reference to them from other sections. | ||||
* | start/user: describe version numbers and releases | Gedare Bloom | 2020-04-02 | 1 | -0/+49 |
| | | | | Closes #2562. | ||||
* | user/rsb: Fix typos (#3922) | Mritunjay | 2020-04-02 | 4 | -10/+10 |
| | | | | Closes #3922 | ||||
* | eng: Add documentation guidelines | Sebastian Huber | 2020-04-02 | 3 | -44/+80 |
| | | | | | | | | | Start with templates for the application configuration options. Remove "Format to be followed for making changes in this file" from c-user. Update #3910. | ||||
* | c-user: Move CONFIGURE_MAXIMUM_PRIORITY | Sebastian Huber | 2020-04-02 | 2 | -58/+58 |
| | | | | | | Move this option to the scheduler configuration options. Update #3836. | ||||
* | c-user: Clarify config options use | Sebastian Huber | 2020-04-02 | 3 | -5/+34 |
* | eng: Add glossary terms | Sebastian Huber | 2020-04-01 | 3 | -9/+169 |
| | | | | | | | | | | | | | | | | | Define the following terms: * assembler language * C language * ELF * interrupt service * software component * software unit Clarify: * task Update #3715. | ||||
* | c-user: Document all configuration options | Sebastian Huber | 2020-04-01 | 7 | -0/+666 |
| | | | | Close #2806. | ||||
* | c-user: Use new template for integer config opts | Sebastian Huber | 2020-04-01 | 14 | -748/+1203 |
| | | | | | | | | | Try to bring all descriptions up to date. Add cross-references to several options. Clarify configuration value constraints. Use this template also for initializer type options. Close #3901. | ||||
* | c-user: Avoid self references | Sebastian Huber | 2020-03-30 | 1 | -3/+3 |
| | | | | Update #3900. | ||||
* | c-user: Use new template for feature config opts | Sebastian Huber | 2020-03-30 | 1 | -23/+35 |
* | c-user: Fix typo in file name | Sebastian Huber | 2020-03-30 | 1 | -0/+0 |
* | user: Use consistent Hello World spelling | Sebastian Huber | 2020-03-30 | 4 | -5/+5 |
* | user: Provide a user friendly configuration | Sebastian Huber | 2020-03-30 | 1 | -4/+4 |
