* | RTEMS Docs: Check sphinx version | Richard Campbell | 2018-03-09 | 2 | -5/+23 |
| | | | | | | | Sphinx.util.compat module was removed at Sphinx version 1.7. Imported module was not being used. Closes #3311. | ||||
* | posix-compliance: Add description of standards | Joel Sherrill | 2018-03-09 | 3 | -5/+84 |
* | c-user: Fix simple SMP scheduler limits | Sebastian Huber | 2018-03-09 | 1 | -1/+1 |
* | c-user: Rework scheduler alogrithm config defs | Sebastian Huber | 2018-03-08 | 1 | -78/+92 |
| | | | | Update #3325. | ||||
* | c-user: Rework clustered scheduling configuration | Sebastian Huber | 2018-03-07 | 2 | -151/+185 |
* | c-user: Use uniprocessor throughout | Sebastian Huber | 2018-03-07 | 7 | -25/+25 |
* | c-user: Sort scheduler configuration options | Sebastian Huber | 2018-03-07 | 1 | -96/+96 |
* | c-user: Promote clustered scheduler configuration | Sebastian Huber | 2018-03-07 | 3 | -8/+7 |
| | | | | Add own section for the clustered scheduler configuration. | ||||
* | c-user: Fix scheduler configuration overview | Sebastian Huber | 2018-03-07 | 2 | -4/+6 |
* | c-user: Update CONFIGURE_SCHEDULER_NAME | Sebastian Huber | 2018-03-07 | 2 | -9/+27 |
* | CONFIGURE_*_SIMPLE_TASK_CONSOLE_DRIVER | Sebastian Huber | 2018-03-06 | 1 | -13/+84 |
| | | | | Update #3320. | ||||
* | CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER | Sebastian Huber | 2018-02-05 | 1 | -0/+39 |
| | | | | | Close #3170. Update #3199. | ||||
* | c-user: Fix index directives | Sebastian Huber | 2018-02-05 | 1 | -0/+10 |
| | | | | Update #3229. | ||||
* | c-user: Use configuration option as section name | Sebastian Huber | 2018-02-05 | 1 | -713/+390 |
| | | | | | | | This makes it easier to find the documentation for a given configuration option. Remove superfluous comments. | ||||
* | c-user: Document obsolete termios config options | Sebastian Huber | 2018-02-05 | 1 | -63/+16 |
| | | | | Update #2843. | ||||
* | c-user: Add self-contained objects chapter | Sebastian Huber | 2018-02-05 | 2 | -0/+1071 |
* | c-user: Clarify user extensions | Sebastian Huber | 2018-01-05 | 1 | -10/+16 |
* | c-user: Update unlimites objects configuration | Sebastian Huber | 2017-12-15 | 1 | -33/+22 |
* | Account for non-preemption and interrupt level not supported on SMP | Joel Sherrill | 2017-12-06 | 2 | -1/+9 |
| | | | | Closes #3000. | ||||
* | c-user: Clarify local interrupt disable | Sebastian Huber | 2017-12-01 | 1 | -3/+6 |
* | c-user: Clarify interrupt manager directives | Sebastian Huber | 2017-11-30 | 1 | -58/+137 |
| | | | | Use RTEMS coding style in all code blocks. | ||||
* | c-user: Document global construction | Sebastian Huber | 2017-11-24 | 2 | -5/+74 |
| | | | | Close #3243. | ||||
* | c-user: Document rtems_panic() | Sebastian Huber | 2017-11-23 | 1 | -4/+42 |
| | | | | Close #3244. | ||||
* | c-user: Remove RTEMS_SYSINIT_POSIX_RWLOCK | Sebastian Huber | 2017-11-22 | 1 | -4/+0 |
| | | | | Update #3115. | ||||
* | c-user: Remove RTEMS_SYSINIT_POSIX_BARRIER | Sebastian Huber | 2017-11-22 | 1 | -4/+0 |
| | | | | Update #3114. | ||||
* | c-user: Remove RTEMS_SYSINIT_POSIX_MUTEX | Sebastian Huber | 2017-11-22 | 1 | -4/+0 |
| | | | | Update #3112. | ||||
* | c-user: RTEMS_SYSINIT_POSIX_CONDITION_VARIABLE | Sebastian Huber | 2017-11-22 | 1 | -4/+0 |
| | | | | Update #3113. | ||||
* | Mention barrier manager in rtems_semaphore_flush() | Sebastian Huber | 2017-11-20 | 2 | -0/+6 |
* | Clarify INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL | Sebastian Huber | 2017-11-20 | 2 | -2/+6 |
| | | | | Update #3239. | ||||
* | c-user: Clarify rtems_interrupt_flash() | Sebastian Huber | 2017-11-20 | 1 | -7/+11 |
* | c-user: Remove clock driver specific functions | Sebastian Huber | 2017-11-17 | 1 | -3/+0 |
| | | | | | | Do not mention functions which belong to a specific clock driver implementation. These functions should not be called by applications directly. | ||||
* | Document INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL | Sebastian Huber | 2017-11-17 | 1 | -0/+4 |
| | | | | Close #3239. | ||||
* | INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT | Sebastian Huber | 2017-11-17 | 1 | -0/+4 |
* | bsp-howto: Add getentropy. | Christian Mauderer | 2017-11-17 | 2 | -0/+40 |
* | c-users: Clarify semaphore obtain/flush | Sebastian Huber | 2017-11-16 | 1 | -1/+43 |
* | bsp-howto/console: Move misplaced var. in example | Martin Erik Werner | 2017-11-16 | 1 | -1/+1 |
| | | | | Signed-off-by: Martin Erik Werner <martinerikwerner@gmail.com> | ||||
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 35 | -428/+708 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | Use '.. toctree::' and not '.. include::' in the User Manual. | Chris Johns | 2017-11-13 | 17 | -228/+30 |
| | | | | | | | | - Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232. | ||||
* | c-user: Fix index locations. | Chris Johns | 2017-11-12 | 36 | -785/+920 |
* | Add indexes to all documents. | Chris Johns | 2017-11-12 | 26 | -27/+65 |
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 16 | -272/+288 |
| | | | | Update #3220. | ||||
* | c-user/configuring_a_system.rst: Delete notepads section | Joel Sherrill | 2017-11-02 | 1 | -32/+0 |
| | | | | closes #3215. | ||||
* | posix-users: Clarify timed operation errors | Sebastian Huber | 2017-10-24 | 2 | -3/+7 |
| | | | | Close #3182. | ||||
* | posix-compliance: Latex does not like an empty glossary. | Chris Johns | 2017-10-13 | 1 | -0/+5 |
* | posix-compliance: Reference the generated content via the include file. | Chris Johns | 2017-10-13 | 5 | -7/+24 |
| | | | | | - Move the copyright to the top of the generated file. - Add a glossary and references section. | ||||
* | posix-compliance: Fix the pdflatex file created by Sphinx. | Chris Johns | 2017-10-12 | 1 | -1/+1 |
* | build: Remove the grouping in posix-compliance. | Chris Johns | 2017-10-12 | 1 | -1/+0 |
* | posix-compliance: Add automatic generation of the ReST file from CSV data. | Chris Johns | 2017-10-12 | 3 | -1/+291 |
| | | | | Closes #3177. | ||||
* | build: Add extra source to the sphinx build. | Chris Johns | 2017-10-12 | 1 | -11/+11 |
| | | | | Updates #3177. | ||||
* | New version of POSIX Compliance Guide | Joel Sherrill | 2017-10-12 | 32 | -7299/+1391 |
| | | | | | | | This is a replacement of the POSIX 1003.1 Compliance Guide. It will be generated from a .csv file. Updates #3177. |
