* | eng/vc-users.rst: Add commit message guidance5.35.25 | Joel Sherrill | 2022-12-14 | 1 | -6/+77 |
| | | | | Closes #4275. | ||||
* | waf: Handle the enable options for singlehtml and ditaa/puml | Chris Johns | 2022-11-11 | 1 | -3/+3 |
| | | | | Close #4755 | ||||
* | waf: Backport from main build fixes | Chris Johns | 2022-11-10 | 5 | -35/+78 |
| | | | | Closes #4752 | ||||
* | task-stack-alloc.rst: Add CONFIGURE_TASK_STACK_FROM_ALLOCATOR | Joel Sherrill | 2021-10-07 | 1 | -1/+35 |
| | | | | Updates #4520. | ||||
* | c-user: Update MrsP semaphore documentation | Sebastian Huber | 2021-03-17 | 1 | -3/+3 |
| | | | | Update #4347. | ||||
* | Add missing <math.h> methods implemented as macros on compiler builtins. | Joel Sherrill | 2020-09-14 | 2 | -1357/+1357 |
| | | | | | | | These methods have long been provided and this change is needed on the 5.x branch and master. Closes #4075. | ||||
* | user: Mention file descriptor changes | Sebastian Huber | 2020-09-02 | 1 | -0/+19 |
* | user: Fix format5.1 | Sebastian Huber | 2020-08-13 | 1 | -1/+1 |
| | | | | Update #3859. | ||||
* | user: Add shell environment migration aid | Sebastian Huber | 2020-08-10 | 1 | -0/+27 |
* | common: Remove probably superfluous import | Sebastian Huber | 2020-08-10 | 1 | -1/+0 |
| | | | | | | | | | The purpose of this import is unclear. This import caused the following error with Sphinx 3.0: Extension error: Could not import extension rtemsdomain (exception: cannot import name 'l_') | ||||
* | c-user: Remove RTEMS_MP_NOT_CONFIGURED error | Sebastian Huber | 2020-06-18 | 4 | -8/+0 |
| | | | | | | | | | | | | | | Some objects can be created with a local or global scope in a multiprocessing network. In non-multiprocessing configurations setting the scope to local or global had no effect since such a system can be viewed as a multiprocessing network with just one node. One and all nodes is the same in such a network. However, if multiprocessing was configured, creation of a global object in a single node network resulted in an RTEMS_MP_NOT_CONFIGURED error. Remove this error condition for symmetry to the non-multiprocessing setup. This is in line with the task affinity behaviour in SMP systems. Close #4005. | ||||
* | c-user: Mention possible preemptions | Sebastian Huber | 2020-06-18 | 7 | -13/+32 |
| | | | | | Mention that object create/delete may case the calling task to be preempted due to the object allocator mutex. | ||||
* | c-user: Use * for list items | Sebastian Huber | 2020-06-17 | 4 | -51/+51 |
* | eng: Clarify action requirement specification | Sebastian Huber | 2020-06-17 | 1 | -6/+136 |
| | | | | Update #3715. | ||||
* | eng: Update action requirement specification | Sebastian Huber | 2020-06-10 | 1 | -1/+80 |
* | eng: Update specification how-to section | Sebastian Huber | 2020-06-08 | 1 | -0/+75 |
* | eng: Add a specification type for actions | Sebastian Huber | 2020-06-08 | 1 | -24/+377 |
| | | | | | | | | | Add support to specify functional requirements for actions (functions or macros) via a transition map of pre-conditions to post-conditions. This will be the work horse for functional requirements. Generation of corresponding validation tests is supported. Update #3715. | ||||
* | eng: Add generic attribute key types | Sebastian Huber | 2020-06-04 | 1 | -26/+37 |
* | eng: Simplify wording for specification items | Sebastian Huber | 2020-06-04 | 1 | -247/+217 |
* | Use a complete sentence for acronym definitions | Sebastian Huber | 2020-06-04 | 2 | -45/+46 |
* | eng: Add interface specification how-to | Sebastian Huber | 2020-06-01 | 2 | -0/+89 |
* | eng: Update requirements tooling section | Sebastian Huber | 2020-05-29 | 1 | -11/+22 |
* | eng: Add generated documentation of spec items | Sebastian Huber | 2020-05-29 | 6 | -414/+4255 |
| | | | | | | | | | The documentation of the specification items is generated by an RTEMS qualification tool from a specification of specification items. Move non-generated content to "req-for-req.rst". Update #3715. | ||||
* | eng: Split up requirements engineering chapter | Sebastian Huber | 2020-05-29 | 9 | -1283/+1309 |
| | | | | | | | This allows to more easily generate the specification item section with a script using specification items. Update #3715. | ||||
* | Spelling/Grammar Mistakes | Richi Dubey | 2020-05-17 | 1 | -25/+25 |
* | eng: Update requirements engineering chapter | Sebastian Huber | 2020-05-05 | 7 | -321/+427 |
| | | | | | | | | | Update requirements engineering chapter due to the removal of Doorstop as the requirements management tool. Update the application configuration related specification items. Update #3715. | ||||
* | Rework RTEMS licensing discussions. | Joel Sherrill | 2020-05-01 | 2 | -14/+96 |
| | | | | | | | This now captures historical rationale along with cross-linking code templates with license guidelines. Closes #3962. | ||||
* | user/rsb: Update the configuration documentation | Chris Johns | 2020-04-28 | 1 | -39/+13 |
| | | | | Closes #3945 | ||||
* | user/tester: Remove command line help as output | Chris Johns | 2020-04-28 | 1 | -31/+2 |
| | | | | Closes #3381 | ||||
* | user: Update the RSB BSP quick start to say where the tests are installed | Chris Johns | 2020-04-28 | 1 | -1/+3 |
| | | | | Closes #3956 | ||||
* | freebsd: Update to reflect the current release 12 requirements | Chris Johns | 2020-04-27 | 1 | -13/+14 |
| | | | | Closes #3960 | ||||
* | c-user: Document rtems_extension_create() | Sebastian Huber | 2020-04-17 | 1 | -0/+2 |
| | | | | Close #3953. | ||||
* | user/imx: Add i.MX6UL/ULL. | Christian Mauderer | 2020-04-15 | 1 | -3/+44 |
| | | | | Update #3869 | ||||
* | c-user: Fix RTEMS_SCHEDULER_EDF_SMP() | Sebastian Huber | 2020-04-15 | 1 | -1/+1 |
| | | | | Update #3815. | ||||
* | eng: Adjust config.h include | Sebastian Huber | 2020-04-15 | 1 | -1/+1 |
| | | | | Use variant used by most source files. | ||||
* | c-user: Split deprecated/removed directives chapter | Sebastian Huber | 2020-04-15 | 1 | -4/+7 |
* | c-user: Add removed directive rtems_clock_get() | Sebastian Huber | 2020-04-15 | 1 | -21/+108 |
| | | | | | | Be in line with Task Manager chapter. Update #2693. | ||||
* | user: Update migration guide | Sebastian Huber | 2020-04-15 | 1 | -12/+44 |
| | | | | Update #3895. | ||||
* | user: Fix start app chmod execute of waf. | Chris Johns | 2020-04-14 | 1 | -1/+1 |
* | user: Document event recording | Sebastian Huber | 2020-04-11 | 1 | -10/+212 |
| | | | | Close #3904. | ||||
* | user/tools/tester.rst: Removes text references to 'erc32-run' and replaces ↵ | Cláudio Maia | 2020-04-09 | 1 | -5/+3 |
| | | | | the example with 'erc32-sis' | ||||
* | user/tools/tester.rst: Removes example using 'sparc-rtems5-run' | Cláudio Maia | 2020-04-09 | 1 | -13/+1 |
* | user/tools/tester.rst: Clarifies the need of --rtems-tools in rtems-test ↵ | Cláudio Maia | 2020-04-09 | 1 | -6/+8 |
| | | | | command line | ||||
* | user/tools/tester.rst: Removes wrong reference to GDB | Cláudio Maia | 2020-04-09 | 1 | -3/+0 |
* | user/tools/tester.rst: Cleans up text | Cláudio Maia | 2020-04-09 | 1 | -80/+90 |
* | rsb/configuration: add my copyright | Gedare Bloom | 2020-04-05 | 1 | -0/+1 |
* | user/rsb: describe how to create configuration reports | Gedare Bloom | 2020-04-05 | 1 | -3/+18 |
| | | | | Closes #3629. | ||||
* | rsb: replace asciidoc with rst formatting | Gedare Bloom | 2020-04-05 | 2 | -10/+10 |
* | user/rsb/configuration: fix typo xy to xz | Gedare Bloom | 2020-04-05 | 1 | -2/+2 |
* | rsb/configuration: fix broken link to _configdir | Gedare Bloom | 2020-04-05 | 1 | -2/+3 |
