* | user: update copyright and minor typo | Gedare Bloom | 2020-04-04 | 2 | -2/+3 | |
* | Chapter-on-need-for-RTEMS-specific-cross-compiler | Utkarsh Rai | 2020-04-04 | 1 | -0/+33 | |
| | | | | Removed '-' character and provided definition list format | |||||
* | common: fix title page | Gedare Bloom | 2020-04-04 | 2 | -1/+2 | |
| | | | | | Sphinx changed the default behavior of maketitle. Provide our own rtemsmaketitle command and use it instead. | |||||
* | Add a release procedure section. | Chris Johns | 2020-04-04 | 2 | -3/+271 | |
* | Update top-level copyrights | Gedare Bloom | 2020-04-03 | 1 | -1/+2 | |
* | RTEMS Docs: Add steps for sphinxcontrib-bibtex | Vaibhav Gupta | 2020-04-03 | 1 | -0/+1 | |
| | | | | | | | | Add step to install sphinxcontrib-bibtex together with the steps mentioned for ArcLinux, to install sphinx and dependencies. Signed-off-by: Vaibhav Gupta <vaibhavgupta40@gmail.com> | |||||
* | waf: User friendly message when no sphinx is installed | Chris Johns | 2020-04-03 | 1 | -0/+3 | |
* | Add virtualenv to the README.txt as the preferred host support. | Chris Johns | 2020-04-03 | 1 | -1/+21 | |
* | doc: Moving M68K BSP Content to User Manual (#3905) | Mritunjay | 2020-04-03 | 1 | -2/+188 | |
| | | | | Fixed trailing spaces. | |||||
* | user/start/gsoc: fix unicode error and grammar typo | Gedare Bloom | 2020-04-02 | 1 | -2/+2 | |
* | start/index: relocate gsoc section | Gedare Bloom | 2020-04-02 | 1 | -1/+1 | |
* | start/gsoc: GSoC Getting started instructions. | G S Niteesh Babu | 2020-04-02 | 3 | -0/+134 | |
| | | | | | Added instructions to setup development environment for students interested in GSoC. | |||||
* | user/bsp-build: Fix broken cross references. | G S Niteesh Babu | 2020-04-02 | 1 | -2/+2 | |
| | | | | | | The QuickStartBSPBuild_Manual and QuickStartBSPBuild_RSB are missing the underscore in front. This breaks any reference to them from other sections. | |||||
* | start/user: describe version numbers and releases | Gedare Bloom | 2020-04-02 | 1 | -0/+49 | |
| | | | | Closes #2562. | |||||
* | user/rsb: Fix typos (#3922) | Mritunjay | 2020-04-02 | 4 | -10/+10 | |
| | | | | Closes #3922 | |||||
* | eng: Add documentation guidelines | Sebastian Huber | 2020-04-02 | 3 | -44/+80 | |
| | | | | | | | | | Start with templates for the application configuration options. Remove "Format to be followed for making changes in this file" from c-user. Update #3910. | |||||
* | c-user: Move CONFIGURE_MAXIMUM_PRIORITY | Sebastian Huber | 2020-04-02 | 2 | -58/+58 | |
| | | | | | | Move this option to the scheduler configuration options. Update #3836. | |||||
* | c-user: Clarify config options use | Sebastian Huber | 2020-04-02 | 3 | -5/+34 | |
* | eng: Add glossary terms | Sebastian Huber | 2020-04-01 | 3 | -9/+169 | |
| | | | | | | | | | | | | | | | | | Define the following terms: * assembler language * C language * ELF * interrupt service * software component * software unit Clarify: * task Update #3715. | |||||
* | c-user: Document all configuration options | Sebastian Huber | 2020-04-01 | 7 | -0/+666 | |
| | | | | Close #2806. | |||||
* | c-user: Use new template for integer config opts | Sebastian Huber | 2020-04-01 | 14 | -748/+1203 | |
| | | | | | | | | | Try to bring all descriptions up to date. Add cross-references to several options. Clarify configuration value constraints. Use this template also for initializer type options. Close #3901. | |||||
* | c-user: Avoid self references | Sebastian Huber | 2020-03-30 | 1 | -3/+3 | |
| | | | | Update #3900. | |||||
* | c-user: Use new template for feature config opts | Sebastian Huber | 2020-03-30 | 1 | -23/+35 | |
* | c-user: Fix typo in file name | Sebastian Huber | 2020-03-30 | 1 | -0/+0 | |
* | user: Use consistent Hello World spelling | Sebastian Huber | 2020-03-30 | 4 | -5/+5 | |
* | user: Provide a user friendly configuration | Sebastian Huber | 2020-03-30 | 1 | -4/+4 | |
* | c-user: Document new event record config options | Sebastian Huber | 2020-03-24 | 1 | -1/+64 | |
| | | | | Update #3904. | |||||
* | c-user: Use new template for feature config opts | Sebastian Huber | 2020-03-24 | 10 | -567/+539 | |
| | | | | | | | Try to bring all descriptions up to date. Add cross-references to several options. Close #3900. | |||||
* | posix-compliance: Add some missing methods | Joel Sherrill | 2020-03-21 | 2 | -220/+220 | |
* | gdbarmsim: Remove all references to this deleted BSP family | Joel Sherrill | 2020-03-20 | 4 | -12/+2 | |
| | | | | Updates #3611. | |||||
* | user/hosts/posix.rst: Add CentOS 8 information | Joel Sherrill | 2020-03-20 | 1 | -2/+18 | |
* | eng: Add Python development guidelines | Sebastian Huber | 2020-03-19 | 2 | -0/+164 | |
* | user/raspberrypi: Fix typo | G S Niteesh Babu | 2020-03-19 | 1 | -1/+1 | |
| | | | | enable-uart should be enable_uart in config.txt | |||||
* | c-user: Canonicalize configuration option groups | Sebastian Huber | 2020-03-18 | 14 | -40/+37 | |
* | c-user: Add reference to proxies | Sebastian Huber | 2020-03-17 | 2 | -3/+4 | |
* | c-user: Fix format | Sebastian Huber | 2020-03-17 | 2 | -36/+36 | |
* | c-user: Add configuration option index entry | Sebastian Huber | 2020-03-17 | 1 | -0/+2 | |
* | c-user: Fix sorting in filesystem configuration | Sebastian Huber | 2020-03-17 | 1 | -2/+2 | |
* | c-user: Add missing configuration option notes | Sebastian Huber | 2020-03-17 | 2 | -1/+49 | |
* | c-user: Sort configuration options alphabetically | Sebastian Huber | 2020-03-17 | 3 | -77/+77 | |
* | c-user: Obsolete CONFIGURE_MAXIMUM_DEVICES | Sebastian Huber | 2020-03-13 | 2 | -30/+10 | |
| | | | | Close #3898. | |||||
* | c-user: Fix typos | Sebastian Huber | 2020-03-13 | 1 | -4/+4 | |
* | c-user: Reorder configuration option groups | Sebastian Huber | 2020-03-13 | 1 | -4/+4 | |
| | | | | | | | Sort the configuration option groups according to the likelihood a user will define options of a group. Update #3836. | |||||
* | c-user: Clarify message buffer configuration | Sebastian Huber | 2020-03-13 | 3 | -94/+73 | |
| | | | | | | | | | The help macro CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE() is not a configuration option. Move it into the documentatation of the CONFIGURE_MESSAGE_BUFFER_MEMORY configuration option. Move this option to the general system configuration group. Update #3836. | |||||
* | c-user: Add copyright information | Sebastian Huber | 2020-03-13 | 1 | -0/+1 | |
| | | | | | | | | | | | | | | | | | Add copyright information according to commit in RTEMS main repository: commit e53aae2676c42cda521328504f82d26c33827021 Author: Gedare Bloom <gedare@rtems.org> Date: Mon Mar 26 16:42:38 2012 -0400 confdefs: Add declaration for unlimited objects. Adds to confdefs a way to specify rtems_resource_unlimited for classic and posix objects using a new macro CONFIGURE_OBJECTS_UNLIMITED. Use CONFIGURE_OBJECTS_ALLOCATION_SIZE to declare the allocation size for extending the set of objects at runtime. Updates the unlimited sample to demonstrate how to use the new macros. Also adds new documentation in the C User's Manual regarding configuring with unlimited objects. | |||||
* | user: Add a migration chapter | Chris Johns | 2020-03-13 | 3 | -0/+115 | |
| | | | | | | | This is a start with the hope we collect useful pieces to aid porting. Please add to this. Closes #3895 | |||||
* | user: Update Quick Start Guide reference. | Chris Johns | 2020-03-13 | 1 | -1/+1 | |
* | waf: Get the version numbers from the version file. | Chris Johns | 2020-03-13 | 4 | -5/+43 | |
* | user: Add anchors to some BSPs. | Chris Johns | 2020-03-13 | 2 | -0/+15 | |
* | sphinx: Add a custom highlight colour | Chris Johns | 2020-03-13 | 1 | -0/+5 | |
| | | | | Update #2998 |
