* | Add some notes on writing documentation. | Chris Johns | 2016-11-01 | 1 | -0/+130 | |
* | rsb: Fix the tex name. | Chris Johns | 2016-10-31 | 1 | -1/+1 | |
* | Ignore waf files. | Chris Johns | 2016-10-31 | 1 | -0/+1 | |
* | RSB: Clean up formatting and fix code-block mistakes. | Joel Sherrill | 2016-10-30 | 1 | -156/+173 | |
* | waf: Add an install command. | Chris Johns | 2016-10-31 | 3 | -46/+77 | |
* | RSB: Make the bullet style more consistent. | Joel Sherrill | 2016-10-30 | 2 | -34/+43 | |
* | RSB: Initial addition | Joel Sherrill | 2016-10-30 | 5 | -0/+3621 | |
| | | | | | | | | The content was manually converted from Asciidoc to Sphinx and there are some areas which remain to be done. Specifically there are some tables and embedded links which are known to remain but there are almost certainly other things to clean up. | |||||
* | waf: Add top build support. | Chris Johns | 2016-10-30 | 3 | -16/+248 | |
* | waf: Add a build date to the copyright. | Chris Johns | 2016-10-30 | 1 | -1/+2 | |
* | waf: Formatting. | Chris Johns | 2016-10-30 | 1 | -2/+2 | |
* | porting: Review and tidy up multiple formatting issues. | Joel Sherrill | 2016-10-28 | 11 | -187/+223 | |
* | filesystem: Fix numbered lists. | Joel Sherrill | 2016-10-28 | 1 | -39/+39 | |
* | c_user: Fix numbered lists. | Joel Sherrill | 2016-10-28 | 2 | -5/+5 | |
* | cpu_supplement: Fixed numbered list | Joel Sherrill | 2016-10-28 | 1 | -24/+24 | |
* | in-memory.rst, mounting_and_unmounting.rst: Remove unnecessary backslash | Joel Sherrill | 2016-10-28 | 2 | -2/+2 | |
* | user: Add comments about warnings we cannot remove. | Chris Johns | 2016-10-29 | 2 | -0/+5 | |
* | user: Add comment to move to packages. | Chris Johns | 2016-10-29 | 1 | -0/+3 | |
* | user: Add hardware layers figure. | Chris Johns | 2016-10-29 | 1 | -0/+0 | |
* | powerpc, sparc, sparc64: Correct tables | Joel Sherrill | 2016-10-28 | 3 | -73/+57 | |
* | Remove the old files. | Chris Johns | 2016-10-29 | 9 | -61699/+0 | |
* | shell: Fix code-block warnings. | Chris Johns | 2016-10-29 | 5 | -294/+293 | |
* | dec_21140.rst, network_task_structure.rst: Change image to figure | Joel Sherrill | 2016-10-28 | 2 | -6/+9 | |
* | dec_21140.rst: Correct path to image | Joel Sherrill | 2016-10-28 | 1 | -1/+1 | |
* | makefiles.rst, target_dependant_files.rst: Fix link | Joel Sherrill | 2016-10-28 | 2 | -1/+3 | |
* | target_dependant_files.rst: Fix spacing and warning. | Joel Sherrill | 2016-10-28 | 1 | -1/+1 | |
* | initilization_code.rst, linker_script.rst: Fix cross reference | Joel Sherrill | 2016-10-28 | 2 | -1/+3 | |
* | waf: Update to support a recent waf. | Chris Johns | 2016-10-29 | 1 | -2/+2 | |
* | object_services.rst: Add _rtems_object_id_api_minimum_class and ↵ | Joel Sherrill | 2016-10-28 | 2 | -1/+67 | |
| | | | | _rtems_object_id_api_maximum_class | |||||
* | bsp_howto: Fix ASCII figure. | Chris Johns | 2016-10-28 | 1 | -11/+11 | |
* | c_user: Remove errors and warnings. | Chris Johns | 2016-10-28 | 11 | -22/+338 | |
* | Update the file list to the 4.11 directory structure. | Chris Johns | 2016-10-27 | 1 | -116/+3 | |
* | Fix filesystem formatting. | Chris Johns | 2016-10-27 | 11 | -1404/+1165 | |
* | porting: Fix code-block markup | Joel Sherrill | 2016-10-27 | 7 | -71/+71 | |
* | bsp_howto: Fix code-block markup | Joel Sherrill | 2016-10-27 | 6 | -21/+21 | |
* | rtems-docs: Fix many unnecessary back slashes | Joel Sherrill | 2016-10-27 | 15 | -96/+96 | |
* | initilization_code.rst: Fix figure formatting | Joel Sherrill | 2016-10-27 | 1 | -7/+7 | |
* | Merge branch 'master' of ssh://dispatch.rtems.org/data/git/rtems-docs | Joel Sherrill | 2016-10-27 | 1 | -1/+8 | |
| * | shell/file_and_directory.rst: Correct mkdos command. | Joel Sherrill | 2016-10-27 | 1 | -1/+8 | |
* | | Misc: Capitalize RTEMS. | Joel Sherrill | 2016-10-27 | 4 | -10/+10 | |
* | develenv/sample.rst: Correct formatting error | Joel Sherrill | 2016-10-27 | 1 | -1/+0 | |
* | develenv: Fix build errors for real | Joel Sherrill | 2016-10-27 | 3 | -9/+6 | |
* | develenv: Fix build errors | Joel Sherrill | 2016-10-27 | 3 | -19/+20 | |
* | ecosys/index.rst: Fix complixity spelling | Joel Sherrill | 2016-10-27 | 1 | -1/+1 | |
* | Fix develenv. Needs more fixes. | Chris Johns | 2016-10-27 | 6 | -767/+603 | |
* | common/waf.py: Improve Sphinx version parsing to work with their git master | Joel Sherrill | 2016-10-27 | 1 | -2/+2 | |
* | Clean up the CPU Supplement. | Chris Johns | 2016-10-07 | 19 | -2420/+1985 | |
* | c_user: Fix minor error. | Chris Johns | 2016-09-14 | 1 | -1/+1 | |
* | waf: Fix for waf-1.9.3. | Chris Johns | 2016-09-09 | 1 | -1/+1 | |
* | Fix the table and section numbering in the User,Hardware,Tiers section. | Chris Johns | 2016-07-06 | 1 | -16/+16 | |
* | Add a Hardware section. | Chris Johns | 2016-07-06 | 9 | -19/+224 | |
