* cpu-supplement: Fix the project label.Chris Johns2016-11-091-0/+2
* develenv: Fix header levels.Chris Johns2016-11-097-10/+11
* eclipse: Fix heading levels.Chris Johns2016-11-094-7/+37
* bsp-howto: Increase the number depth of sections.Chris Johns2016-11-091-1/+1
* cpu-supplement: Fix header levels.Chris Johns2016-11-0921-23/+24
* bsp-howto: Fix header levels.Chris Johns2016-11-0920-23/+22
* README: Add coding of spaces and no trailing white space.Chris Johns2016-11-091-7/+9
* README: Fix the header levels.Chris Johns2016-11-091-6/+8
* user: Fix header levels.Chris Johns2016-11-0928-65/+88
* shell: Fix header levels.Chris Johns2016-11-099-15/+11
* c-user: Fix header levels. Minor fixes.Chris Johns2016-11-0938-57/+55
* latex: Increase the depth of subsections.Chris Johns2016-11-091-4/+7
* README.txt: Add notes on Centos 6 and 7Joel Sherrill2016-11-081-5/+46
* c-user: Correct copyright attribution to match original texinfo filesJoel Sherrill2016-11-082-4/+5
* shell: Update commands to use descriptions.Chris Johns2016-11-087-4488/+4303
* waf: Get a copy of the optional packages.Chris Johns2016-11-081-2/+2
* waf: Use the good fonts if installed.Chris Johns2016-11-085-22/+49
* c-user: Format the directives as descriptions.Chris Johns2016-11-0830-8135/+7796
| | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals.
* pdf: Format lists for directives to sit on the next line.Chris Johns2016-11-083-2/+7
* Add openSUSE installation hintsSebastian Huber2016-11-071-1/+14
* PDF: Do not use lato and inconsolata fonts. Not widely supported.Chris Johns2016-11-074-146/+5
* waf: Add a program test for pygmentize.Chris Johns2016-11-071-0/+3
* README: Add packages for building on Arch.Christian Mauderer2016-11-071-0/+12
* waf: Fix ''NoneType' object is not iterable'Christian Mauderer2016-11-071-4/+6
* README: Update with more host specific details.Chris Johns2016-11-061-18/+40
* waf: Fix the host version check.Chris Johns2016-11-061-3/+3
* waf: Add support to handle missing Latex packages on hosts they are not ↵Chris Johns2016-11-0611-95/+1113
| | | | | | | | | | available on. It appears the support for texlive packages on some hosts is variable. This patch lets us add missing packages to our source tree so a PDF can be built on those hosts. The quality of the PDFs created may vary as some short cuts may have been take. For example lato is a font and only the sty file as been added and not the actual font which means it's use will default to another font.
* waf: note about tex noise when running configure.Chris Johns2016-11-041-0/+3
* README: Add host set up for CentOS for singlehtml.Chris Johns2016-11-041-0/+5
* waf: Check for texlive packages and report an error is not found.Chris Johns2016-11-042-9/+198
* waf: Fix the bnode issue when building in a manual directory.Chris Johns2016-11-041-1/+1
* Update due to clock manager and driver changesSebastian Huber2016-11-037-109/+28
* Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns2016-11-03139-11/+9
* waf: Use separate doctrees so avoid sphinx clashes.Chris Johns2016-11-031-10/+11
* pdf: Make the copyright the same as the html.Chris Johns2016-11-031-1/+1
* conf: Make the build date use a nicer day format.Chris Johns2016-11-031-1/+16
* README: Add host set up and update the build commands.Chris Johns2016-11-031-5/+38
* waf: Have configure set building pdf and/or singlehtml.Chris Johns2016-11-031-206/+247
| | | | | | | | | | | | | | Move selecting pdf and singlehtml to the configure stage so it is sticky for all builds. This means a top level build will always build all formats that have been configured. Do not complete the configure stage if tools are missing for the configured output. Add singlehtml support using the inliner tool. It is nice. Remove the groups as waf can track the dependences. This lets the manuals build in parallel.
* RSB: Fix the history.Chris Johns2016-11-022-33/+9
* Add a copyright to the PDF front page.Chris Johns2016-11-022-3/+4
* RSB: Fix the heading level for the PDF.Chris Johns2016-11-0210-100/+112
* Update the top level README.txt.Chris Johns2016-11-021-9/+19
* Fix spelling.Chris Johns2016-11-021-1/+1
* RSB: Finish reformatting after moving from asciidocs.Chris Johns2016-11-0211-3504/+3534
* html: Update the CSS and add topics.Chris Johns2016-11-021-8/+30
* waf: Fix the sphinx verbose option.Chris Johns2016-11-021-2/+8
* c_user: Re-add task notepads for 4.11. Remove this patch after branching.Joel Sherrill2016-11-012-0/+146
* Add some notes on writing documentation.Chris Johns2016-11-011-0/+130
* rsb: Fix the tex name.Chris Johns2016-10-311-1/+1
* Ignore waf files.Chris Johns2016-10-311-0/+1
