* | spec: Move specification of specification items | Sebastian Huber | 2020-09-18 | 30 | -1007/+0 |
| | | | | This makes it reusable. | ||||
* | spec: Unify test attribute keys | Sebastian Huber | 2020-08-19 | 2 | -16/+16 |
* | spec: Add test header to test case item type | Sebastian Huber | 2020-08-19 | 5 | -20/+24 |
* | validation: Remove explicit test names | Sebastian Huber | 2020-08-19 | 4 | -30/+0 |
* | validation: Add test context support | Sebastian Huber | 2020-08-19 | 1 | -0/+7 |
* | validation: Add test cleanup | Sebastian Huber | 2020-08-19 | 1 | -0/+7 |
* | validation: Add test early preparation | Sebastian Huber | 2020-08-19 | 1 | -0/+7 |
* | spec: Fix item format | Sebastian Huber | 2020-08-19 | 1 | -1/+1 |
* | spec: Add reference to unspecified interfaces | Sebastian Huber | 2020-08-06 | 1 | -0/+5 |
* | spec: Add more unspecified interfaces | Sebastian Huber | 2020-08-06 | 1 | -0/+12 |
* | spec: Clarify and use interface brief | Sebastian Huber | 2020-07-28 | 2 | -4/+7 |
* | validation: Add ability to skip action transitions | Sebastian Huber | 2020-07-27 | 3 | -0/+41 |
* | validation: Support N/A in the action transitions | Sebastian Huber | 2020-07-27 | 2 | -4/+12 |
| | | | | | Sometimes the pre-conditions are not independent and it is necessary to mark pre-conditions as not applicable in a particular transition. | ||||
* | spec: Add requirements text to groups | Sebastian Huber | 2020-07-24 | 1 | -0/+4 |
* | spec: Add header file brief descriptions | Sebastian Huber | 2020-07-24 | 1 | -0/+4 |
* | spec: Fix typo | Sebastian Huber | 2020-07-03 | 1 | -1/+1 |
* | spec: Clarify action requirements | Sebastian Huber | 2020-06-17 | 2 | -6/+131 |
* | spec: Fix typo | Sebastian Huber | 2020-06-17 | 1 | -1/+1 |
* | spec: Specify action requirement test headers | Sebastian Huber | 2020-06-10 | 4 | -1/+105 |
* | staging: Fix functional requirement item types | Sebastian Huber | 2020-06-08 | 3 | -25/+40 |
* | spec: Generalize directive to action requirements | Sebastian Huber | 2020-06-08 | 15 | -80/+89 |
* | spec: Fix specification type | Sebastian Huber | 2020-06-08 | 1 | -3/+0 |
* | spec: Specify directive requirement items | Sebastian Huber | 2020-06-08 | 16 | -0/+454 |
* | spec: Define generic attribute key types | Sebastian Huber | 2020-06-08 | 4 | -11/+19 |
* | spec: Rename required in mandatory attributes | Sebastian Huber | 2020-06-08 | 99 | -112/+111 |
| | | | | | | | | The term "required" is quite overloaded in the specification context. Use "mandatory" instead. Shorten the phrase "explicitly defined attributes" to "explicit attributes". | ||||
* | spec: Canonicalize descriptions | Sebastian Huber | 2020-06-08 | 2 | -15/+13 |
* | spec: Fix attribute order | Sebastian Huber | 2020-06-08 | 2 | -8/+8 |
* | spec: Add test procedure and platform types | Sebastian Huber | 2020-06-08 | 2 | -0/+76 |
* | spec: Move glossary terms | Sebastian Huber | 2020-06-04 | 3 | -4/+4 |
| | | | | | The previous structure was a relict of the Doorstop era. This makes it easier to reference terms via ${/glossary/abc:/term} substitutions. | ||||
* | spec: Add requirement references | Sebastian Huber | 2020-05-28 | 4 | -0/+69 |
* | spec: Add content from engineering manual | Sebastian Huber | 2020-05-28 | 4 | -4/+27 |
* | spec: Add examples | Sebastian Huber | 2020-05-28 | 12 | -12/+242 |
* | spec: Reuse interface description and notes | Sebastian Huber | 2020-05-28 | 2 | -10/+9 |
* | specverify: Improve contains operation | Sebastian Huber | 2020-05-28 | 1 | -3/+1 |
* | spec: Canonicalize specification of items | Sebastian Huber | 2020-05-28 | 20 | -22/+22 |
* | specdoc: Use mapper substitutions for descriptions | Sebastian Huber | 2020-05-28 | 15 | -51/+49 |
* | spec: Add interface domain items | Sebastian Huber | 2020-05-28 | 3 | -11/+42 |
* | spec: Add interface-target link role | Sebastian Huber | 2020-05-28 | 2 | -7/+28 |
* | spec: Add dedicated constraint items | Sebastian Huber | 2020-05-28 | 2 | -6/+41 |
* | spec: Add specification of requirement validation | Sebastian Huber | 2020-05-28 | 3 | -0/+87 |
* | spec: Canonicalize specification of specification | Sebastian Huber | 2020-05-28 | 41 | -157/+141 |
* | spec: Add rationale attribute to requirements | Sebastian Huber | 2020-05-28 | 1 | -0/+5 |
* | Rename custom constraints attribute | Sebastian Huber | 2020-05-28 | 2 | -4/+19 |
| | | | | | Uses "texts" to be in line with the "text" attribute of constraint items. | ||||
* | Add constraint link role | Sebastian Huber | 2020-05-28 | 2 | -5/+25 |
* | Rename application configuration attributes | Sebastian Huber | 2020-05-28 | 5 | -17/+17 |
* | spec: Add specification of test items | Sebastian Huber | 2020-05-28 | 7 | -0/+237 |
* | spec: Add specification of interface items | Sebastian Huber | 2020-05-28 | 42 | -6/+1124 |
* | spec: Add specification of interface group items | Sebastian Huber | 2020-05-28 | 2 | -0/+55 |
* | spec: Sort attributes | Sebastian Huber | 2020-05-28 | 9 | -97/+97 |
* | spec: Add specification of glossary items | Sebastian Huber | 2020-05-28 | 4 | -0/+87 |
