* | spec: Rename required in mandatory attributes | Sebastian Huber | 2020-06-08 | 1 | -1/+1 |
| | | | | | | | | The term "required" is quite overloaded in the specification context. Use "mandatory" instead. Shorten the phrase "explicitly defined attributes" to "explicit attributes". | ||||
* | spec: Fix attribute order | Sebastian Huber | 2020-06-08 | 1 | -4/+4 |
* | spec: Add test procedure and platform types | Sebastian Huber | 2020-06-08 | 1 | -0/+36 |
