* | spec: Fix function reference | Sebastian Huber | 2020-09-25 | 1 | -3/+3 |
* | spec: Fix attribute validation test | Sebastian Huber | 2020-09-18 | 1 | -3/+3 |
* | spec: Delete resources in validation tests | Sebastian Huber | 2020-09-18 | 8 | -8/+31 |
* | spec: Add OAR copyright to <rtems.h> | Sebastian Huber | 2020-09-18 | 1 | -1/+2 |
| | | | | Clarify brief description. | ||||
* | spec: Move multiprocessing API defines | Sebastian Huber | 2020-09-18 | 2 | -0/+0 |
* | spec: Fix typo | Sebastian Huber | 2020-09-17 | 1 | -1/+1 |
* | spec: Use rtems_task_construct() | Sebastian Huber | 2020-09-17 | 2 | -24/+51 |
* | spec: Fix references | Sebastian Huber | 2020-09-17 | 1 | -3/+3 |
* | spec: Fix typo | Sebastian Huber | 2020-09-16 | 1 | -1/+1 |
* | spec: Document rtems_task_construct(), ... | Sebastian Huber | 2020-09-16 | 2 | -6/+27 |
* | spec: Group items by component | Sebastian Huber | 2020-09-16 | 666 | -0/+21213 |
