* | spec: Fix warning | Sebastian Huber | 2021-04-07 | 1 | -3/+2 |
* | spec: Use tc-support.h | Sebastian Huber | 2021-03-22 | 2 | -93/+21 |
* | spec: Simplify /rtems/signal/req/catch | Sebastian Huber | 2021-03-19 | 1 | -779/+173 |
* | spec: Canonicalize directives | Sebastian Huber | 2021-03-19 | 1 | -17/+11 |
| | | | | Use common wording and the new templates for action requirements. | ||||
* | spec: Improve or fix wording | Sebastian Huber | 2021-03-11 | 1 | -4/+6 |
* | spec: Add memory benchmarks | Sebastian Huber | 2021-03-10 | 2 | -0/+69 |
* | spec: Use common wording | Sebastian Huber | 2021-03-08 | 1 | -1/+2 |
* | spec: Improve signal catch specification | Sebastian Huber | 2021-03-02 | 1 | -7/+155 |
* | spec: Fix wording | Sebastian Huber | 2021-02-19 | 1 | -1/+1 |
* | spec: Specify signal manager | Sebastian Huber | 2021-02-19 | 2 | -0/+1629 |
* | spec: Document signal manager | Sebastian Huber | 2021-02-19 | 37 | -51/+177 |
* | spec: Add function attributes | Sebastian Huber | 2020-10-12 | 2 | -0/+2 |
* | spec: Move index-entries to interface type | Sebastian Huber | 2020-10-07 | 40 | -0/+40 |
* | spec: Group items by component | Sebastian Huber | 2020-09-16 | 40 | -0/+812 |
