2023-05-19 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2023-05-08 | spec: Use ${xzy:/spec} for item references | Sebastian Huber | 1 | -1/+1 | |
2021-02-04 | spec: Rename test case action attributes | Sebastian Huber | 1 | -4/+4 | |
The new attribute keys make it easier to write test cases. | |||||
2021-02-04 | validation: Remove prologue/epilogue in test cases | Sebastian Huber | 1 | -2/+0 | |
2021-02-04 | validation: Add context and fixture to test case | Sebastian Huber | 1 | -1/+5 | |
2020-09-16 | spec: Group items by component | Sebastian Huber | 1 | -6/+5 | |
2020-08-20 | spec: Specify Event Manager | Sebastian Huber | 1 | -0/+66 | |
