* | spec: Use tr-* file pattern for test runs | Sebastian Huber | 2020-08-19 | 1 | -1/+1 |
* | spec: Unify test attribute keys | Sebastian Huber | 2020-08-19 | 1 | -17/+17 |
* | spec: Add test header to test case item type | Sebastian Huber | 2020-08-19 | 1 | -0/+1 |
* | validation: Remove explicit test names | Sebastian Huber | 2020-08-19 | 1 | -1/+0 |
* | spec: Fix item format | Sebastian Huber | 2020-08-19 | 1 | -10/+10 |
* | spec: Fix requirement items | Sebastian Huber | 2020-07-03 | 1 | -0/+2 |
* | spec: Add object name to id actions | Sebastian Huber | 2020-07-03 | 2 | -0/+58 |
