* | spec: Specify rtems_task_create_from_config() | Sebastian Huber | 2020-09-11 | 11 | -90/+301 |
* | spec: Fix item format | Sebastian Huber | 2020-08-19 | 16 | -42/+22 |
* | spec: Synchronize with RTEMS | Sebastian Huber | 2020-08-19 | 1 | -1/+1 |
* | spec: Update RTEMS_ZERO_LENGTH_ARRAY | Sebastian Huber | 2020-08-07 | 2 | -3/+6 |
* | spec: Fix formatting | Sebastian Huber | 2020-08-06 | 6 | -6/+6 |
* | spec: Improve formatting | Sebastian Huber | 2020-08-06 | 1 | -2/+2 |
* | spec: Add references for some C types and defines | Sebastian Huber | 2020-08-06 | 17 | -17/+17 |
* | spec: Add reference to unspecified interfaces | Sebastian Huber | 2020-08-06 | 181 | -0/+181 |
* | spec: Improve references in appl config options | Sebastian Huber | 2020-08-06 | 118 | -111/+522 |
* | spec: Clarify event receive description | Sebastian Huber | 2020-07-28 | 1 | -5/+5 |
* | spec: Add top-level requirement for the system | Sebastian Huber | 2020-07-24 | 1 | -0/+2 |
* | spec: Add requirements text to groups | Sebastian Huber | 2020-07-24 | 30 | -113/+176 |
* | spec: Move interface groups | Sebastian Huber | 2020-07-24 | 549 | -520/+1060 |
* | spec: Add header file brief descriptions | Sebastian Huber | 2020-07-24 | 59 | -0/+77 |
* | spec: Add event manager documentation | Sebastian Huber | 2020-07-24 | 16 | -53/+177 |
* | spec: Fix rtems_isr_entry for some CPU ports | Sebastian Huber | 2020-07-23 | 1 | -2/+4 |
* | spec: Avoid Sphinx-specific :file: | Sebastian Huber | 2020-07-07 | 5 | -5/+5 |
* | spec: Use ${...} references in /if/acfg/* | Sebastian Huber | 2020-07-07 | 110 | -295/+283 |
| | | | | This allows generation of Sphinx and Doxygen output. | ||||
* | spec: Move application configuration items | Sebastian Huber | 2020-07-07 | 176 | -4/+4463 |
* | spec: Document name to id directives | Sebastian Huber | 2020-07-03 | 10 | -75/+419 |
* | spec: Specify <rtems.h> | Sebastian Huber | 2020-07-03 | 1 | -0/+86 |
* | spec: Add /if/rtems/userext/* | Sebastian Huber | 2020-07-03 | 29 | -0/+472 |
* | spec: Add /if/rtems/timer/* | Sebastian Huber | 2020-07-03 | 25 | -0/+682 |
* | spec: Add /if/rtems/support/* | Sebastian Huber | 2020-07-03 | 12 | -0/+377 |
* | spec: Add /if/rtems/signal/* | Sebastian Huber | 2020-07-03 | 39 | -0/+790 |
* | spec: Add /if/rtems/region/* | Sebastian Huber | 2020-07-03 | 13 | -0/+412 |
* | spec: Add /if/rtems/ratemon/* | Sebastian Huber | 2020-07-03 | 20 | -0/+593 |
* | spec: Add /if/rtems/part/* | Sebastian Huber | 2020-07-03 | 6 | -0/+197 |
* | spec: Add /if/rtems/object/* | Sebastian Huber | 2020-07-03 | 45 | -0/+975 |
* | spec: Add /if/rtems/mp/* | Sebastian Huber | 2020-07-03 | 2 | -0/+36 |
* | spec: Add /if/rtems/message/* | Sebastian Huber | 2020-07-03 | 10 | -0/+357 |
* | spec: Add /if/rtems/io/* | Sebastian Huber | 2020-07-03 | 17 | -0/+543 |
* | spec: Add /if/rtems/intr/* | Sebastian Huber | 2020-07-03 | 54 | -0/+992 |
* | spec: Add /if/rtems/fatal/* | Sebastian Huber | 2020-07-03 | 12 | -0/+300 |
* | spec: Add /if/rtems/event/* | Sebastian Huber | 2020-07-03 | 49 | -0/+1081 |
* | spec: Add /if/rtems/dpmem/* | Sebastian Huber | 2020-07-03 | 6 | -0/+197 |
* | spec: Add /if/rtems/clock/* | Sebastian Huber | 2020-07-03 | 21 | -0/+524 |
* | spec: Add /if/rtems/cache/* | Sebastian Huber | 2020-07-03 | 25 | -0/+703 |
* | spec: Add /if/rtems/barrier/* | Sebastian Huber | 2020-07-03 | 6 | -0/+185 |
* | spec: Add /if/rtems/sem/* | Sebastian Huber | 2020-07-03 | 8 | -0/+401 |
* | spec: Add /if/rtems/tasks/* | Sebastian Huber | 2020-07-03 | 58 | -1/+1876 |
* | spec: Add /if/rtems/attr/* | Sebastian Huber | 2020-07-03 | 23 | -0/+476 |
* | spec: Add /if/rtems/types/* | Sebastian Huber | 2020-07-03 | 41 | -0/+652 |
* | spec: Add /if/rtems/options/* | Sebastian Huber | 2020-07-03 | 7 | -0/+135 |
* | spec: Add /if/rtems/modes/* | Sebastian Huber | 2020-07-03 | 19 | -0/+385 |
* | spec: Add /if/rtems/config/* | Sebastian Huber | 2020-07-03 | 5 | -1/+82 |
* | spec: Improve /if/rtems/basedefs/* | Sebastian Huber | 2020-07-03 | 4 | -3/+13 |
* | interface: Support automatic Doxygen links | Sebastian Huber | 2020-07-03 | 1 | -2/+1 |
* | spec: Fix /if/rtems/config/* | Sebastian Huber | 2020-06-08 | 2 | -1/+4 |
* | spec: Add interface domain items | Sebastian Huber | 2020-05-28 | 55 | -74/+164 |
