2020-09-16 | spec: Group items by component | Sebastian Huber | 1 | -26/+0 | |
2020-07-24 | spec: Move interface groups | Sebastian Huber | 1 | -1/+1 | |
2020-07-03 | spec: Add /if/rtems/clock/* | Sebastian Huber | 1 | -3/+3 | |
2020-07-03 | spec: Add /if/rtems/cache/* | Sebastian Huber | 1 | -3/+3 | |
2020-07-03 | spec: Add /if/rtems/config/* | Sebastian Huber | 1 | -5/+4 | |
2020-05-28 | spec: Add function body attribute | Sebastian Huber | 1 | -0/+1 | |
2020-05-28 | Rename interface attributes | Sebastian Huber | 1 | -13/+13 | |
2020-05-28 | spec: Add more interface specification items | Sebastian Huber | 1 | -5/+7 | |
2020-05-28 | Change format of enabled-by attribute | Sebastian Huber | 1 | -1/+1 | |
2020-05-28 | interface: Add "interface-notes" attribute | Sebastian Huber | 1 | -0/+1 | |
2020-05-28 | interface: Support void functions | Sebastian Huber | 1 | -6/+12 | |
2020-05-28 | interface: Allow defines without a value | Sebastian Huber | 1 | -1/+1 | |
2020-05-28 | tests: Sort attributes alphabetically | Sebastian Huber | 1 | -2/+2 | |
2020-05-28 | interface: Use enabled_by_to_exp() | Sebastian Huber | 1 | -6/+10 | |
2020-05-28 | interface: New module | Sebastian Huber | 1 | -0/+13 | |
