* | spec: Document rtems_task_construct(), ... | Sebastian Huber | 2020-09-16 | 1 | -0/+5 |
* | spec: Group items by component | Sebastian Huber | 2020-09-16 | 175 | -0/+4545 |
* | spec: Move application configuration items | Sebastian Huber | 2020-07-07 | 173 | -4459/+0 |
* | spec: Fix /if/acfg/max-processors minimum | Sebastian Huber | 2020-07-07 | 1 | -1/+1 |
* | spec: Allow dual licensing | Sebastian Huber | 2020-07-03 | 173 | -173/+173 |
| | | | | | | | | | | | | | | | The items have the following copyright statements: * Copyright (C) 2019, 2020 embedded brains GmbH (http://www.embedded-brains.de) * Copyright (C) 2010 Gedare Bloom * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR) The copyright holders agreed to the relicensing according to this ticket: https://devel.rtems.org/ticket/3899 | ||||
* | spec: Use * for list items | Sebastian Huber | 2020-06-17 | 9 | -51/+51 |
* | spec: Add dedicated constraint items | Sebastian Huber | 2020-05-28 | 10 | -30/+20 |
* | spec: Add rationale attribute to requirements | Sebastian Huber | 2020-05-28 | 10 | -0/+10 |
* | Rename custom constraints attribute | Sebastian Huber | 2020-05-28 | 26 | -31/+31 |
| | | | | | Uses "texts" to be in line with the "text" attribute of constraint items. | ||||
* | Add constraint link role | Sebastian Huber | 2020-05-28 | 41 | -127/+161 |
* | Rename application configuration attributes | Sebastian Huber | 2020-05-28 | 163 | -1676/+1676 |
* | spec: Make constraints non-functional requirements | Sebastian Huber | 2020-05-28 | 10 | -10/+30 |
* | spec: Add requirement-refinement link role | Sebastian Huber | 2020-05-28 | 14 | -14/+14 |
* | spec: Add appl-config-group-member link role | Sebastian Huber | 2020-05-28 | 149 | -149/+149 |
* | Change format of enabled-by attribute | Sebastian Huber | 2020-05-28 | 173 | -173/+173 |
* | Remove Doorstop specifics | Sebastian Huber | 2020-04-21 | 175 | -1955/+868 |
* | spec: Move option | Sebastian Huber | 2020-04-02 | 1 | -1/+1 |
* | spec: Clarify config options use | Sebastian Huber | 2020-04-01 | 11 | -5/+46 |
* | spec: Use null if no notes are present | Sebastian Huber | 2020-04-01 | 43 | -86/+43 |
* | spec: Add and use constraint | Sebastian Huber | 2020-04-01 | 6 | -20/+26 |
* | spec: Add undocumented configuration options | Sebastian Huber | 2020-03-31 | 23 | -0/+650 |
* | spec: New option template | Sebastian Huber | 2020-03-31 | 1 | -0/+9 |
* | spec: Clarify role in configuration option | Sebastian Huber | 2020-03-30 | 2 | -2/+4 |
* | spec: Use constraint links | Sebastian Huber | 2020-03-30 | 42 | -250/+233 |
* | spec: Replace "must" with "shall" | Sebastian Huber | 2020-03-30 | 67 | -94/+94 |
* | spec: Avoid self references | Sebastian Huber | 2020-03-30 | 3 | -3/+3 |
* | spec: Add BSP related config options | Sebastian Huber | 2020-03-30 | 8 | -0/+289 |
* | spec: Convert initializer options | Sebastian Huber | 2020-03-30 | 11 | -103/+119 |
* | spec: Canonicalize integer options | Sebastian Huber | 2020-03-30 | 5 | -17/+19 |
* | spec: Fix CONFIGURE_MAXIMUM_DRIVERS | Sebastian Huber | 2020-03-27 | 1 | -3/+3 |
* | spec: Convert integer feature options | Sebastian Huber | 2020-03-27 | 58 | -545/+768 |
* | spec: Update copyright | Sebastian Huber | 2020-03-24 | 1 | -1/+1 |
* | spec: Use option type "feature-enable" | Sebastian Huber | 2020-03-24 | 39 | -166/+61 |
* | spec: Fix format | Sebastian Huber | 2020-03-21 | 1 | -1/+1 |
* | spec: Add event record config options | Sebastian Huber | 2020-03-19 | 2 | -0/+69 |
* | spec: Convert boolean feature options | Sebastian Huber | 2020-03-19 | 50 | -518/+496 |
* | spec: Add application configuration | Sebastian Huber | 2020-03-17 | 133 | -0/+4372 |
