* | interfacedoc: Fix format of parameter names | Sebastian Huber | 2020-12-02 | 1 | -5/+10 |
* | items: Catch all YAML errors | Sebastian Huber | 2020-12-02 | 2 | -4/+4 |
* | interface/interfacedoc: Format parameter names | Sebastian Huber | 2020-12-01 | 5 | -2/+17 |
* | items: Enable custom get value for lists | Sebastian Huber | 2020-12-01 | 4 | -73/+59 |
* | glossary: Use ItemMapper.add_get_value() | Sebastian Huber | 2020-12-01 | 1 | -8/+8 |
* | Format specification items | Sebastian Huber | 2020-11-30 | 1 | -3/+3 |
* | Revert "interfacedoc: Strip leading "_" from parameters" | Sebastian Huber | 2020-11-24 | 1 | -6/+3 |
| | | | | This reverts commit d459b58772183bb987f350c4b463ff05c012520e. | ||||
* | interfacedoc: Strip leading "_" from parameters | Sebastian Huber | 2020-11-24 | 1 | -3/+6 |
* | interfacedoc: Support macros | Sebastian Huber | 2020-11-24 | 3 | -15/+144 |
* | items: Improve YAML parser error messages | Sebastian Huber | 2020-11-20 | 3 | -1/+19 |
* | specdoc: Fix typo | Sebastian Huber | 2020-11-19 | 2 | -4/+4 |
* | validation: Support for runtime performance reqs | Sebastian Huber | 2020-11-13 | 5 | -8/+220 |
* | validation: Support for runtime measurement tests | Sebastian Huber | 2020-11-13 | 4 | -11/+309 |
* | validation: Move add function to base class | Sebastian Huber | 2020-11-13 | 1 | -9/+15 |
* | validation: Move add context to base class | Sebastian Huber | 2020-11-13 | 1 | -28/+35 |
* | validation: Move add fixture method to base class | Sebastian Huber | 2020-11-13 | 1 | -27/+51 |
* | validation: Fix names | Sebastian Huber | 2020-11-13 | 1 | -32/+30 |
* | specdoc/specverify: Support values of any type | Sebastian Huber | 2020-11-12 | 5 | -2/+21 |
* | content: Improve automatically generated warning | Sebastian Huber | 2020-11-11 | 6 | -80/+64 |
* | interface: Substitute group descriptions | Sebastian Huber | 2020-11-06 | 1 | -1/+2 |
* | glossary: Remove global state | Sebastian Huber | 2020-11-05 | 1 | -3/+3 |
| | | | | Initialize the dictionaries each time the glossary() function is called. | ||||
* | items: Add Link.__setitem__() | Sebastian Huber | 2020-10-28 | 2 | -0/+5 |
* | specverify: Fix type annotation | Sebastian Huber | 2020-10-28 | 1 | -2/+2 |
* | items: Add ItemCache.updates | Sebastian Huber | 2020-10-28 | 2 | -0/+14 |
* | items: Detect file removals in item cache | Sebastian Huber | 2020-10-28 | 2 | -1/+8 |
* | glossary: Make project glossary optional | Sebastian Huber | 2020-10-26 | 2 | -2/+12 |
* | glossary: Support custom glossary headers | Sebastian Huber | 2020-10-26 | 2 | -11/+15 |
* | glossary: Find term plurals | Sebastian Huber | 2020-10-26 | 2 | -1/+9 |
* | sphinxcontent: Support recursive mappings | Sebastian Huber | 2020-10-26 | 1 | -2/+2 |
* | items: Add Item.cache | Sebastian Huber | 2020-10-24 | 2 | -2/+13 |
* | specverify: Add SpecVerify.verify() | Sebastian Huber | 2020-10-23 | 2 | -6/+63 |
* | specverify: Add SpecVerify.verify_all() | Sebastian Huber | 2020-10-23 | 2 | -19/+72 |
| | | | | Introduce a VerifyStatus tuple with an aggregated verify status. | ||||
* | specverify: Introduce SpecVerifier class | Sebastian Huber | 2020-10-23 | 1 | -23/+31 |
* | items: Add ItemCache.add_volatile_item() | Sebastian Huber | 2020-10-23 | 2 | -29/+58 |
* | items: Add Item parent() and child() methods | Sebastian Huber | 2020-10-21 | 4 | -5/+31 |
* | interface: No implicit groups for headers | Sebastian Huber | 2020-10-13 | 2 | -23/+14 |
* | interface: Support function attributes | Sebastian Huber | 2020-10-12 | 3 | -4/+6 |
* | spec: Add function attributes | Sebastian Huber | 2020-10-12 | 4 | -0/+5 |
* | spec: Fix format | Sebastian Huber | 2020-10-12 | 1 | -6/+6 |
* | interface: Micro optimize | Sebastian Huber | 2020-10-11 | 1 | -2/+2 |
* | interface: Improve ordering | Sebastian Huber | 2020-10-11 | 3 | -64/+106 |
| | | | | Close #4134. | ||||
* | interface: Improve naming | Sebastian Huber | 2020-10-11 | 1 | -15/+16 |
* | interfacedoc: Use item.type | Sebastian Huber | 2020-10-11 | 1 | -4/+3 |
* | spec: Rename documentation in placement order | Sebastian Huber | 2020-10-11 | 2 | -4/+4 |
* | interfacedoc: Use a key function to sort the items | Sebastian Huber | 2020-10-09 | 1 | -14/+17 |
* | applconfig: Add "Generated from ..." comments | Sebastian Huber | 2020-10-08 | 2 | -6/+61 |
* | interface: Add "Generated from ..." comments | Sebastian Huber | 2020-10-08 | 2 | -0/+32 |
* | interfacedoc: Various improvements | Sebastian Huber | 2020-10-08 | 6 | -106/+267 |
* | spec: Move index-entries to interface type | Sebastian Huber | 2020-10-07 | 42 | -145/+187 |
* | interface: Simplify | Sebastian Huber | 2020-10-07 | 1 | -26/+18 |
