path: root/rtemsspec (follow)
* validation: Use call_function()Sebastian Huber2020-09-112-18/+12
* content: Split long @defgroup linesSebastian Huber2020-09-112-1/+26
* interface: Fix macro linksSebastian Huber2020-09-112-2/+3
* interface: Add Doxygen links to config optionsSebastian Huber2020-09-102-1/+4
* validation: Add automatically generated warningSebastian Huber2020-08-192-0/+65
* interface: Add automatically generated warningSebastian Huber2020-08-192-0/+10
* specdoc: Add automatically generated warningSebastian Huber2020-08-192-0/+8
* content: Add add_automatically_generated_warning()Sebastian Huber2020-08-192-13/+16
* build: Gather test header filesSebastian Huber2020-08-195-3/+36
* validation: Add test documentation to groupSebastian Huber2020-08-193-71/+60
* validation: Add ${step/123} supportSebastian Huber2020-08-193-22/+24
* validation: Add test header for test casesSebastian Huber2020-08-194-59/+400
* spec: Unify test attribute keysSebastian Huber2020-08-196-86/+91
* spec: Add test header to test case item typeSebastian Huber2020-08-194-0/+4
* validation: Fix typosSebastian Huber2020-08-191-2/+2
* items: Add Item.specSebastian Huber2020-08-193-1/+11
* validation: Use dictionary to gather itemsSebastian Huber2020-08-191-16/+36
* validation: Update due to test API changesSebastian Huber2020-08-192-12/+14
* validation: Remove explicit test namesSebastian Huber2020-08-198-260/+258
* validation: Add test context supportSebastian Huber2020-08-194-0/+6
* validation: Add test cleanupSebastian Huber2020-08-194-0/+11
* validation: Add test early preparationSebastian Huber2020-08-194-6/+22
* content: Add to_camel_case()Sebastian Huber2020-08-192-9/+13
* spec: Fix item formatSebastian Huber2020-08-197-48/+48
* content: Strip function parametersSebastian Huber2020-08-193-3/+7
* validation: Move action code to separate functionSebastian Huber2020-08-072-4/+22
* validation: Fix N/A scope descriptionSebastian Huber2020-08-072-7/+14
* validation: Clarify skip action transitionsSebastian Huber2020-08-072-3/+3
* applconfig: Add automatically generated warningSebastian Huber2020-08-072-0/+29
* content: Add Content.comment_block()Sebastian Huber2020-08-074-7/+41
* applconfig: Add references for unspec interfacesSebastian Huber2020-08-067-4/+83
* applconfig: Improve interface mappingsSebastian Huber2020-08-066-8/+71
* content: Improve CContent.doxyfy()Sebastian Huber2020-08-062-0/+7
| | | | Add replacement for :file:`xyz`.
* specdoc: Fix typoSebastian Huber2020-08-061-1/+1
* specdoc: Fix output format of regular expressionsSebastian Huber2020-07-282-3/+3
* validation: Add ability to skip action transitionsSebastian Huber2020-07-274-48/+116
* validation: Support N/A in the action transitionsSebastian Huber2020-07-273-46/+266
| | | | | Sometimes the pre-conditions are not independent and it is necessary to mark pre-conditions as not applicable in a particular transition.
* items: Improve ItemCache exception messageSebastian Huber2020-07-273-2/+18
* spec: Add header file brief descriptionsSebastian Huber2020-07-248-0/+9
* interfacedoc: Simplify interface referencesSebastian Huber2020-07-242-11/+10
* validation: Use <rtems/test.h> instead of <t.h>Sebastian Huber2020-07-232-5/+5
* Rename "rtemsqual" in "rtemsspec"Sebastian Huber2020-07-15214-0/+15483
