* | Rename "rtemsqual" in "rtemsspec" | Sebastian Huber | 2020-07-15 | 1 | -14/+14 |
* | rtems_spec_to_x.py: Fix type checking issue | Sebastian Huber | 2020-06-08 | 1 | -0/+1 |
* | spec: Add some interface items | Sebastian Huber | 2020-05-28 | 1 | -0/+2 |
* | Run doxygen in pre-qualified workspace | Sebastian Huber | 2020-05-28 | 1 | -0/+18 |
* | Generate a test suite with two test cases | Sebastian Huber | 2020-05-28 | 1 | -0/+2 |
* | Remove Doorstop specifics | Sebastian Huber | 2020-04-21 | 1 | -1/+4 |
* | util: Add copy_files() | Sebastian Huber | 2020-04-17 | 1 | -6/+1 |
* | util: New module | Sebastian Huber | 2020-04-17 | 1 | -3/+2 |
| | | | | Add recursive include for configuration file. | ||||
* | Move pre-qualified only config.ini into config.yml | Sebastian Huber | 2020-04-17 | 1 | -7/+3 |
* | Rename config.ini in config.yml | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | build: New module | Sebastian Huber | 2020-04-16 | 1 | -3/+45 |
* | applconfig: Rework | Sebastian Huber | 2020-03-17 | 1 | -0/+2 |
* | Initial import | Sebastian Huber | 2020-03-02 | 1 | -0/+43 |
