* | spec: Move specification of specification items | Sebastian Huber | 2020-09-18 | 1 | -0/+1 |
| | | | | This makes it reusable. | ||||
* | specdoc: Make section texts configurable | Sebastian Huber | 2020-09-18 | 1 | -2/+8 |
* | specdoc: Make label prefix configurable | Sebastian Huber | 2020-09-18 | 1 | -0/+1 |
* | spec: Group items by component | Sebastian Huber | 2020-09-16 | 1 | -20/+20 |
* | config.yml: Fix UIDs | Sebastian Huber | 2020-07-27 | 1 | -2/+2 |
* | config: Generate event manager documentation | Sebastian Huber | 2020-07-24 | 1 | -0/+3 |
* | Rename "external" in "modules" | Sebastian Huber | 2020-07-15 | 1 | -25/+25 |
* | applconfig: Add Doxygen output | Sebastian Huber | 2020-07-07 | 1 | -0/+1 |
* | spec: Move application configuration items | Sebastian Huber | 2020-07-07 | 1 | -14/+14 |
* | items: Add support for aggregated item type | Sebastian Huber | 2020-07-03 | 1 | -0/+1 |
* | spec2doc.py: Generate interface documentation | Sebastian Huber | 2020-07-03 | 1 | -0/+4 |
* | spec: Move glossary terms | Sebastian Huber | 2020-06-04 | 1 | -1/+1 |
| | | | | | The previous structure was a relict of the Doorstop era. This makes it easier to reference terms via ${/glossary/abc:/term} substitutions. | ||||
* | spec: Add interface domain items | Sebastian Huber | 2020-05-28 | 1 | -4/+4 |
* | Rename interface attributes | Sebastian Huber | 2020-05-28 | 1 | -1/+1 |
* | Add specdoc.py | Sebastian Huber | 2020-05-28 | 1 | -0/+3 |
* | Add specverify.py | Sebastian Huber | 2020-05-28 | 1 | -0/+2 |
* | spec: Add some interface items | Sebastian Huber | 2020-05-28 | 1 | -0/+7 |
* | Run doxygen in pre-qualified workspace | Sebastian Huber | 2020-05-28 | 1 | -0/+3 |
* | Generate a test suite with two test cases | Sebastian Huber | 2020-05-28 | 1 | -0/+2 |
* | Remove Doorstop specifics | Sebastian Huber | 2020-04-21 | 1 | -18/+18 |
* | Do not install legacy Makefiles | Sebastian Huber | 2020-04-17 | 1 | -0/+1 |
* | Move pre-qualified only config.ini into config.yml | Sebastian Huber | 2020-04-17 | 1 | -0/+7 |
* | Rename config.ini in config.yml | Sebastian Huber | 2020-04-16 | 1 | -0/+68 |
