2020-09-18 | spec: Move specification of specification items | Sebastian Huber | 1 | -0/+1 | |
This makes it reusable. | |||||
2020-09-18 | specdoc: Make section texts configurable | Sebastian Huber | 1 | -2/+8 | |
2020-09-18 | specdoc: Make label prefix configurable | Sebastian Huber | 1 | -0/+1 | |
2020-09-16 | spec: Group items by component | Sebastian Huber | 1 | -20/+20 | |
2020-07-27 | config.yml: Fix UIDs | Sebastian Huber | 1 | -2/+2 | |
2020-07-24 | config: Generate event manager documentation | Sebastian Huber | 1 | -0/+3 | |
2020-07-15 | Rename "external" in "modules" | Sebastian Huber | 1 | -25/+25 | |
2020-07-07 | applconfig: Add Doxygen output | Sebastian Huber | 1 | -0/+1 | |
2020-07-07 | spec: Move application configuration items | Sebastian Huber | 1 | -14/+14 | |
2020-07-03 | items: Add support for aggregated item type | Sebastian Huber | 1 | -0/+1 | |
2020-07-03 | spec2doc.py: Generate interface documentation | Sebastian Huber | 1 | -0/+4 | |
2020-06-04 | spec: Move glossary terms | Sebastian Huber | 1 | -1/+1 | |
The previous structure was a relict of the Doorstop era. This makes it easier to reference terms via ${/glossary/abc:/term} substitutions. | |||||
2020-05-28 | spec: Add interface domain items | Sebastian Huber | 1 | -4/+4 | |
2020-05-28 | Rename interface attributes | Sebastian Huber | 1 | -1/+1 | |
2020-05-28 | Add specdoc.py | Sebastian Huber | 1 | -0/+3 | |
2020-05-28 | Add specverify.py | Sebastian Huber | 1 | -0/+2 | |
2020-05-28 | spec: Add some interface items | Sebastian Huber | 1 | -0/+7 | |
2020-05-28 | Run doxygen in pre-qualified workspace | Sebastian Huber | 1 | -0/+3 | |
2020-05-28 | Generate a test suite with two test cases | Sebastian Huber | 1 | -0/+2 | |
2020-04-21 | Remove Doorstop specifics | Sebastian Huber | 1 | -18/+18 | |
2020-04-17 | Do not install legacy Makefiles | Sebastian Huber | 1 | -0/+1 | |
2020-04-17 | Move pre-qualified only config.ini into config.yml | Sebastian Huber | 1 | -0/+7 | |
2020-04-16 | Rename config.ini in config.yml | Sebastian Huber | 1 | -0/+0 | |
2020-04-16 | build: New module | Sebastian Huber | 1 | -0/+25 | |
2020-04-06 | items: Use a cache file directory | Sebastian Huber | 1 | -1/+1 | |
This allows read-only source trees. | |||||
2020-04-06 | Add RTEMS build specification | Sebastian Huber | 1 | -0/+1 | |
2020-03-30 | spec: Add BSP related config options | Sebastian Huber | 1 | -0/+2 | |
2020-03-17 | applconfig: Rework | Sebastian Huber | 1 | -0/+28 | |
