* | Changed CONFIGURATION_MICROSECONDS_PER_TICK definition to a more reasonable | Joel Sherrill | 1999-12-14 | 1 | -1/+1 |
| | | | | value. | ||||
* | Added call to rtems_bsdnet_show_inet_routes(). | Joel Sherrill | 1999-02-10 | 1 | -0/+1 |
* | Added CVS Id Strings which were missing | Joel Sherrill | 1998-08-21 | 3 | -0/+9 |
* | KA9Q -> FreeBSD changes from Eric Norum | Joel Sherrill | 1998-08-21 | 3 | -179/+71 |
* | Cleaned up USE_BOOTP conditional for initialization. | Joel Sherrill | 1998-08-12 | 2 | -9/+4 |
| | | | | | | Get info from usercfg.h now. Added message indicating test is exitting. | ||||
* | Added print. | Joel Sherrill | 1998-08-08 | 1 | -0/+1 |
* | Moved debugging hints to new file. | Joel Sherrill | 1998-07-30 | 1 | -11/+0 |
* | Switched to using "../user.cfg" | Joel Sherrill | 1998-07-30 | 1 | -26/+10 |
* | Added notes from Eric to README. | Joel Sherrill | 1998-07-30 | 4 | -0/+25 |
| | | | | Added CVS $Id$ to all files. | ||||
* | base from Eric Norum -- Demos.30May1998.tar.gzDemos-30May1998ERIC-NORUM | Joel Sherrill | 1998-07-30 | 4 | -0/+584 |
