* | 2008-08-08 Joel Sherrill <joel.sherrill@OARcorp.com>network-demos-4-7-3network-demos-4-7-branch | Joel Sherrill | 2008-08-08 | 2 | -1/+5 |
| | | | | * VERSION: Updated to network-demos-4.7.3. | ||||
* | 2008-02-14 Joel Sherrill <joel.sherrill@OARcorp.com>network-demos-4-7-2 | Joel Sherrill | 2008-02-14 | 2 | -1/+5 |
| | | | | * VERSION: Updated to network-demos-4.7.2. | ||||
* | 2007-12-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-11 | 2 | -0/+22 |
| | | | | * Makefile: New file. | ||||
* | 2007-11-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-11-28 | 14 | -7/+35 |
| | | | | * init.c: Update from CVS head to be buildable. | ||||
* | 2007-11-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-11-28 | 6 | -11/+15 |
| | | | | * init.c, system.h: Update from CVS head to be buildable. | ||||
* | 2007-04-13 Joel Sherrill <joel@OARcorp.com>network-demos-4-7-1 | Joel Sherrill | 2007-04-13 | 2 | -1/+5 |
| | | | | * VERSION: Updated to network-demos-4.7.1. | ||||
* | 2007-04-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-04-13 | 4 | -4/+10 |
| | | | | * system.h: Correct URLs. | ||||
* | 2007-03-05 Joel Sherrill <joel@OARcorp.com>network-demos-4-7-0 | Joel Sherrill | 2007-03-05 | 2 | -1/+5 |
| | | | | * VERSION: Updated to network-demos-4.7.0. | ||||
* | This commit was manufactured by cvs2svn to create branch 'network- | cvs2git | 2006-04-20 | 0 | -0/+0 |
| | | | | | | | demos-4-7-branch'. Sprout from master 2006-04-20 22:35:44 UTC Joel Sherrill <joel.sherrill@OARcorp.com> 'Fix typos.' Cherrypick from ERIC-NORUM 1998-07-30 14:42:29 UTC Joel Sherrill <joel.sherrill@OARcorp.com> 'base from Eric Norum -- Demos.30May1998.tar.gz': ttcp/ttcp_orig/ttcp.1 | ||||
* | Fix typos. | Joel Sherrill | 2006-04-20 | 1 | -3/+0 |
* | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-09-02 | 2 | -1/+53 |
| | | | | * VERSION: Updated to network-demos-4.6.99.2. | ||||
* | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-28 | 2 | -1/+5 |
| | | | | * VERSION: Updated to network-demos-20030128. | ||||
* | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-28 | 14 | -3/+49 |
| | | | | | * init.c: Increase number of file descriptors and use IMFS instead of mini-IMFS as filesystem. | ||||
* | 2002-10-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-21 | 1 | -2/+2 |
| | | | | * VERSION: Updated to network-demos-20021018. | ||||
* | 2002-10-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-18 | 2 | -1/+5 |
| | | | | * VERSION: Updated to /usr1/rtems/releases/netdemos-20021018. | ||||
* | 2002-10-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-18 | 2 | -0/+10 |
| | | | | | | | | * dnstest/init.c, netdemo/init.c, netlink/init.c, ntp/init.c, rpc_demo/init.c, select/init.c, tftpTest/init.c, ttcp/init.c: define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS to 20 for enough sockets and CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM even if not absolutely needed for networking. | ||||
* | changed version to ss-20010831 | Joel Sherrill | 2001-08-31 | 1 | -6/+2 |
* | 2001-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-08-31 | 2 | -0/+26 |
| | | | | * SUPPORT: New file. | ||||
* | 2001-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-08-31 | 7 | -164/+118 |
| | | | | | | | * README, networkconfig.h, netdemo/README, tftpTest/test.c: Merged missing stuff from 4.5 branch. * http/Makefile, http/init.c: Minor modifications to improve buildability. | ||||
* | 2000-12-14 Eric Norum <eric.norum@usask.ca> | Joel Sherrill | 2000-12-14 | 2 | -1/+8 |
| | | | | * networkconfig.h: Default to using bootp host for tftp test. | ||||
* | 2000-12-14 Eric Norum <eric.norum@usask.ca> | Joel Sherrill | 2000-12-14 | 3 | -38/+150 |
| | | | | * init.c, test.c: Added test of write capability. | ||||
* | 2000-12-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-12-14 | 10 | -0/+30 |
| | | | | * ChangeLog: New file. | ||||
* | Patch from Andrew Bythell <abythell@nortelnetworks.com> that should | Joel Sherrill | 2000-07-12 | 5 | -8/+42 |
| | | | | | | allow the http demo to build a correct starting filesystem and run. Formerly, the http demo did not configure the filesystem as needed or build the tar file such that GoAhead could find it. | ||||
* | Adding and deleting files for branch and main trunk. | Joel Sherrill | 2000-07-12 | 4 | -15/+0 |
* | new file added on 4.5 branch | Joel Sherrill | 2000-05-09 | 1 | -0/+0 |
* | New test from Eric Norum <eric@cls.usask.ca> to exercise RPC/XDR. | Joel Sherrill | 2000-04-29 | 8 | -0/+413 |
* | Changed version to 20000104. | Joel Sherrill | 2000-01-04 | 1 | -1/+1 |
* | Changed CONFIGURATION_MICROSECONDS_PER_TICK definition to a more reasonable | Joel Sherrill | 1999-12-14 | 9 | -11/+24 |
| | | | | value. | ||||
* | Changed version to 19991116. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Cleaned up to make it a bit easier to generate sizes. | Joel Sherrill | 1999-11-16 | 1 | -2/+11 |
* | New test to determine network application sizes. | Joel Sherrill | 1999-11-12 | 5 | -0/+320 |
* | Patch from Eric Norum <eric@cls.usask.ca> to add the new fields to | Joel Sherrill | 1999-11-10 | 1 | -1/+23 |
| | | | | the network configuration example. | ||||
* | New ntp demo test from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-10 | 2 | -0/+143 |
* | Changed version to 19991028. | Joel Sherrill | 1999-10-28 | 1 | -1/+1 |
* | New httpd sample test from Emmanuel Raguet. | Joel Sherrill | 1999-10-28 | 4 | -0/+201 |
* | Changed version to 19990820. | Joel Sherrill | 1999-08-20 | 1 | -1/+1 |
* | Patch from Eric Norum <eric@cls.usask.ca>: | Joel Sherrill | 1999-07-12 | 1 | -1/+3 |
| | | | | | | | I changed the TFTP test program and TFTP driver to reflect the changes in the way paths are passed to the TFTP driver. The TFTP driver now needs a proper `dotted-decimal' hostname as the second component of the path name. | ||||
* | Changed version to 199900709. | Joel Sherrill | 1999-07-09 | 1 | -3/+4 |
* | Patch from Ian Lance Taylor <ian@airs.com> to test new "interrupt-ish" | Joel Sherrill | 1999-06-11 | 1 | -10/+113 |
| | | | | | | | | | | driven select on socket support. After the patch to RTEMS, I have appended a patch to netdemos-19990407/select/test.c to test the new functionality and demonstrate one way it might be used. To run the new test instead of the select test, change doSocket to call echoServer2 instead of echoServer. | ||||
* | Updated. | Joel Sherrill | 1999-06-11 | 1 | -2/+3 |
* | Changed to bogus information. | Joel Sherrill | 1999-04-07 | 1 | -9/+14 |
* | Patch from Eric Norum <eric@skatter.usask.ca> to take advantage of new | Joel Sherrill | 1999-04-01 | 1 | -13/+0 |
| | | | | routines in RTEMS. | ||||
* | Added debug print when test can't get a buffer. This is probably a fatal | Joel Sherrill | 1999-02-10 | 1 | -0/+1 |
| | | | | | error in the stack but it would be nice to get a message from the test just in case. | ||||
* | Modified to delay at startup. | Joel Sherrill | 1999-02-10 | 1 | -0/+3 |
* | Modified to support TFTP filesystem. | Joel Sherrill | 1999-02-10 | 1 | -7/+1 |
* | Added call to rtems_bsdnet_show_inet_routes(). | Joel Sherrill | 1999-02-10 | 1 | -0/+1 |
* | Removed warnings. | Joel Sherrill | 1999-02-10 | 1 | -3/+3 |
* | Modified so warnings would be printed if no network driver was defined. | Joel Sherrill | 1999-02-10 | 1 | -6/+25 |
* | Removing socket test. | Joel Sherrill | 1999-02-10 | 10 | -1268/+0 |
* | changed version to 19981217 | Joel Sherrill | 1998-12-17 | 1 | -1/+1 |
