- added rtems_mii_phy_probe(). This is a helper albeit RTEMS specific.
Porting the whole MII/media stuff is still too much ATM.
- removed files that are generated by autreconf after checkout
and added them to .cvsignore
included commits to RCS files with non-trunk default branches.
(SLAC tag 'joel-bsd-drivers-20090214')
Cherrypick from master 2009-02-19 20:05:44 UTC Joel Sherrill <joel.sherrill@OARcorp.com> '2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com>':
bsd_eth_drivers/if_em/e1000_manage.c
bsd_eth_drivers/if_em/e1000_manage.h
* configure.ac, bsd_eth_drivers/Makefile.am,
bsd_eth_drivers/libbsdport/alldrv.c,
bsd_eth_drivers/libbsdport/libbsdport_api.h: Add first cut at
Broadcomm BCM57xx driver.
* bsd_eth_drivers/if_bge/.cvsignore,
bsd_eth_drivers/if_bge/Makefile.am, bsd_eth_drivers/if_bge/if_bge.c,
bsd_eth_drivers/if_bge/if_bgereg.h: New files.
APIs are really different.
- must not use INTR_FAST anymore since this will (deliberately) produce
a compile-time error (see <sys/bus.h>)
hint what the porter has to do.
the newer API calls a 'filter' -- however, it must be equipped
with a proper return value.
- as long as MII stuff is not implememented we fake an OK link
by setting rl_link=1.
- removed re_intr_check_dis(), re_intr_en()
* bsd_eth_drivers/re/if_re.c: Almost runs.
* bsd_eth_drivers/libbsdport/sysbus.c: Revert Till's patch.
* bsd_eth_drivers/if_em/e1000_manage.c,
bsd_eth_drivers/if_em/e1000_manage.h: New files.
Missed in initial import.
* .cvsignore, networkconfig-qemu.h, bsd_eth_drivers/.cvsignore,
bsd_eth_drivers/if_em/.cvsignore, bsd_eth_drivers/if_le/.cvsignore,
bsd_eth_drivers/if_pcn/.cvsignore,
bsd_eth_drivers/libbsdport/.cvsignore,
bsd_eth_drivers/re/.cvsignore: New files.
