path: root/bsd_eth_drivers/libbsdport/miistuff.c (follow)
* This commit was manufactured by cvs2svn to create tag 'R_20100307_p0'.R_20100307_p0cvs2git2010-03-071-0/+58
Sprout from base 2009-04-22 22:06:58 UTC Till Straumann <strauman@slac.stanford.edu> ' - importing updated version from SLAC as of 20090422' Cherrypick from master 2010-03-07 17:11:23 UTC Till Straumann <strauman@slac.stanford.edu> '2010-03-07 Till Straumann <Till.Straumann@TU-Berlin.de>': bsd_eth_drivers/.cvsignore bsd_eth_drivers/ChangeLog bsd_eth_drivers/Makefile.am bsd_eth_drivers/if_bge/.cvsignore bsd_eth_drivers/if_bge/Makefile.am bsd_eth_drivers/if_bge/if_bge.c bsd_eth_drivers/if_bge/if_bgereg.h bsd_eth_drivers/if_em/.cvsignore bsd_eth_drivers/if_em/Makefile.am bsd_eth_drivers/if_em/e1000_manage.c bsd_eth_drivers/if_em/e1000_manage.h bsd_eth_drivers/if_em/e1000_osdep.h bsd_eth_drivers/if_em/if_em.c bsd_eth_drivers/if_fxp/.cvsignore bsd_eth_drivers/if_fxp/Makefile.am bsd_eth_drivers/if_fxp/if_fxp.c bsd_eth_drivers/if_fxp/if_fxpvar.h bsd_eth_drivers/if_le/.cvsignore bsd_eth_drivers/if_pcn/.cvsignore bsd_eth_drivers/if_pcn/if_pcn.c bsd_eth_drivers/if_re/.cvsignore bsd_eth_drivers/if_re/Makefile.am bsd_eth_drivers/if_re/if_re.c bsd_eth_drivers/if_re/if_rl.c bsd_eth_drivers/if_re/if_rlreg.h bsd_eth_drivers/libbsdport/.cvsignore bsd_eth_drivers/libbsdport/Makefile.am bsd_eth_drivers/libbsdport/alldrv.c bsd_eth_drivers/libbsdport/bus.h bsd_eth_drivers/libbsdport/callout.h bsd_eth_drivers/libbsdport/devicet.c bsd_eth_drivers/libbsdport/ifmedia.c bsd_eth_drivers/libbsdport/libbsdport.h bsd_eth_drivers/libbsdport/libbsdport_api.h bsd_eth_drivers/libbsdport/libbsdport_post.h bsd_eth_drivers/libbsdport/miistuff.c bsd_eth_drivers/libbsdport/misc.c bsd_eth_drivers/libbsdport/mutex.h bsd_eth_drivers/libbsdport/rtems_callout.c bsd_eth_drivers/libbsdport/sysbus.c bsd_eth_drivers/libbsdport/taskqueue.h bsd_eth_drivers/links.am Cherrypick from freebsd_orig 2009-04-23 04:52:05 UTC Till Straumann <strauman@slac.stanford.edu> ' - importing original 'releng_7_1' version of FXP driver from FreeBSD.': bsd_eth_drivers/if_fxp/if_fxpreg.h bsd_eth_drivers/if_fxp/rcvbundl.h Delete: INSTALL Makefile.am bootstrap config.h.in configure.ac m4/acinclude.m4 m4/config-if-present.m4 m4/cvstag.m4 m4/multilib-fix.m4 m4/multilib-installdir.m4 m4/rtems-bsp-postlink.m4 m4/rtems-bsplist.m4 m4/rtems-check-libargs.m4 m4/rtems-checkprog.m4 m4/rtems-checktool.m4 m4/rtems-checktop.m4 m4/rtems-fixup-prefix.m4 m4/rtems-isml.m4 m4/rtems-ismultibsp.m4 m4/rtems-isrtems.m4 m4/rtems-makevars.m4 m4/rtems-multilib.m4 m4/rtems-options.m4 m4/rtems-setup-recurse.m4 m4/rtems-tools.m4 m4/rtems-trim-builddir.m4 m4/rtems-verscheck.m4 makefile.top.am makefile.top.in rtems-pre.am rtems.am ssrlApps.components.in
