path: root/bsd_eth_drivers/libbsdport/libbsdport_api.h (follow)
* 2009-10-20 Chris Johns <chrisj@rtems.org>Chris Johns2009-10-201-1/+4
| | | | | | | | | | | | | | | | | | | | | * bsd_eth_drivers/libbsdport/sysbus.cL Fixed the print message for no IRQ handler. * bsd_eth_drivers/libbsdport/misc.c: Add m_defrag and what else it needed. The RL driver needs it. * bsd_eth_drivers/libbsdport/libbsdport_post.h: Remove the define for m_defrag. * bsd_eth_drivers/libbsdport/libbsdport.h: Add if_maddr_rlock and if_maddr_runlock. * bsd_eth_drivers/libbsdport/bus.h: Add the bus_space_write_stream_4 call. * bsd_eth_drivers/libbsdport/libbsdport_post.h, bsd_eth_drivers/libbsdport/alldrv.c, bsd_eth_drivers/if_re/Makefile.am: Add RL driver support. * bsd_eth_drivers/if_re/if_re.c, bsd_eth_drivers/if_re/if_rlreg.h: Updated to the lastest version. * bsd_eth_drivers/if_re/if_rl.c: New. This is for the Realtek 8129/8139 PCI NIC while the RE driver does only the 8139C+ version.
* 2009-06-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-06-041-0/+1
| | | | | * libbsdport/alldrv.c, libbsdport/libbsdport_api.h: Add include <stdio.h> for FILE *.
* - added FXP driverTill Straumann2009-04-231-0/+2
* 2009-02-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-02-201-1/+7
| | | | | | | | | | * configure.ac, bsd_eth_drivers/Makefile.am, bsd_eth_drivers/libbsdport/alldrv.c, bsd_eth_drivers/libbsdport/libbsdport_api.h: Add first cut at Broadcomm BCM57xx driver. * bsd_eth_drivers/if_bge/.cvsignore, bsd_eth_drivers/if_bge/Makefile.am, bsd_eth_drivers/if_bge/if_bge.c, bsd_eth_drivers/if_bge/if_bgereg.h: New files.
* Initial import.initialJoel Sherrill2009-02-191-0/+84
