APIs are really different.
- must not use INTR_FAST anymore since this will (deliberately) produce
a compile-time error (see <sys/bus.h>)
the newer API calls a 'filter' -- however, it must be equipped
with a proper return value.
- as long as MII stuff is not implememented we fake an OK link
by setting rl_link=1.
- removed re_intr_check_dis(), re_intr_en()
* bsd_eth_drivers/re/if_re.c: Almost runs.
* .cvsignore, networkconfig-qemu.h, bsd_eth_drivers/.cvsignore,
bsd_eth_drivers/if_em/.cvsignore, bsd_eth_drivers/if_le/.cvsignore,
bsd_eth_drivers/if_pcn/.cvsignore,
bsd_eth_drivers/libbsdport/.cvsignore,
bsd_eth_drivers/re/.cvsignore: New files.
