* | - use separate #ifdef __rtems__ branch when using bus_setup_intr() because | Till Straumann | 2009-02-20 | 1 | -1/+6 |
| | | | | | | APIs are really different. - must not use INTR_FAST anymore since this will (deliberately) produce a compile-time error (see <sys/bus.h>) | ||||
* | - compute hashes for multicast filtering (UNTESTED) | Till Straumann | 2009-02-20 | 1 | -1/+16 |
* | - added mdio callbacks and rtems specific code to poll the phy. | Till Straumann | 2009-02-20 | 1 | -12/+67 |
* | - fixed arguments to bus_setup_intr(); 're_intr' is really what | Till Straumann | 2009-02-20 | 1 | -2/+22 |
| | | | | | | | | the newer API calls a 'filter' -- however, it must be equipped with a proper return value. - as long as MII stuff is not implememented we fake an OK link by setting rl_link=1. - removed re_intr_check_dis(), re_intr_en() | ||||
* | 2009-02-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-20 | 1 | -23/+8 |
| | | | | * bsd_eth_drivers/re/if_re.c: Almost runs. | ||||
* | Initial import.initial | Joel Sherrill | 2009-02-19 | 1 | -0/+2890 |
