* if_re/if_re.c: fixed 'unused variable' warning by
commenting via #ifndef __rtems__ (since code which uses
the 'msi_disable' var is commented the same way).
* bsd_eth_drivers/libbsdport/sysbus.cL Fixed the print message for
no IRQ handler.
* bsd_eth_drivers/libbsdport/misc.c: Add m_defrag and what else it
needed. The RL driver needs it.
* bsd_eth_drivers/libbsdport/libbsdport_post.h: Remove the define
for m_defrag.
* bsd_eth_drivers/libbsdport/libbsdport.h: Add if_maddr_rlock and
if_maddr_runlock.
* bsd_eth_drivers/libbsdport/bus.h: Add the
bus_space_write_stream_4 call.
* bsd_eth_drivers/libbsdport/libbsdport_post.h,
bsd_eth_drivers/libbsdport/alldrv.c,
bsd_eth_drivers/if_re/Makefile.am: Add RL driver support.
* bsd_eth_drivers/if_re/if_re.c, bsd_eth_drivers/if_re/if_rlreg.h:
Updated to the lastest version.
* bsd_eth_drivers/if_re/if_rl.c: New. This is for the Realtek
8129/8139 PCI NIC while the RE driver does only the 8139C+
version.
APIs are really different.
- must not use INTR_FAST anymore since this will (deliberately) produce
a compile-time error (see <sys/bus.h>)
the newer API calls a 'filter' -- however, it must be equipped
with a proper return value.
- as long as MII stuff is not implememented we fake an OK link
by setting rl_link=1.
- removed re_intr_check_dis(), re_intr_en()
* bsd_eth_drivers/re/if_re.c: Almost runs.
