* | - removed definition of 'bootverbose' (now in libbsdport) | Till Straumann | 2009-04-23 | 1 | -7/+16 |
| | | | | | | | | | | - removed definition of 'bswap32' (now in libbsdport) - removed definition of 'callout_active' (now in libbsdport) - removed definition of 'callout_pending' (now in libbsdport) - removed bus_dmamap_load() -- I believe the version from libbsdport should work (but setting the bus addr to zero probably not). - added (__rtems__) specific code to set multicast address filter - added ETHER_SIOCMULTIFRAG() macro (__rtems__ specific) to ioctl. | ||||
* | 2009-02-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-20 | 4 | -0/+7554 |
* configure.ac, bsd_eth_drivers/Makefile.am, bsd_eth_drivers/libbsdport/alldrv.c, bsd_eth_drivers/libbsdport/libbsdport_api.h: Add first cut at Broadcomm BCM57xx driver. * bsd_eth_drivers/if_bge/.cvsignore, bsd_eth_drivers/if_bge/Makefile.am, bsd_eth_drivers/if_bge/if_bge.c, bsd_eth_drivers/if_bge/if_bgereg.h: New files. |
