path: root/ChangeLog (unfollow)
2009-10-202009-10-20 Chris Johns <chrisj@rtems.org>Chris Johns1-0/+21
* bsd_eth_drivers/libbsdport/sysbus.cL Fixed the print message for no IRQ handler. * bsd_eth_drivers/libbsdport/misc.c: Add m_defrag and what else it needed. The RL driver needs it. * bsd_eth_drivers/libbsdport/libbsdport_post.h: Remove the define for m_defrag. * bsd_eth_drivers/libbsdport/libbsdport.h: Add if_maddr_rlock and if_maddr_runlock. * bsd_eth_drivers/libbsdport/bus.h: Add the bus_space_write_stream_4 call. * bsd_eth_drivers/libbsdport/libbsdport_post.h, bsd_eth_drivers/libbsdport/alldrv.c, bsd_eth_drivers/if_re/Makefile.am: Add RL driver support. * bsd_eth_drivers/if_re/if_re.c, bsd_eth_drivers/if_re/if_rlreg.h: Updated to the lastest version. * bsd_eth_drivers/if_re/if_rl.c: New. This is for the Realtek 8129/8139 PCI NIC while the RE driver does only the 8139C+ version.
2009-05-132009-05-13 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-0/+4
* rtems-pre.am, m4/rtems-fixup-prefix.m4: Install in standard location.
2009-02-202009-02-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-0/+4
* INSTALL: Attempt to update.
2009-02-202009-02-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-0/+10
* configure.ac, bsd_eth_drivers/Makefile.am, bsd_eth_drivers/libbsdport/alldrv.c, bsd_eth_drivers/libbsdport/libbsdport_api.h: Add first cut at Broadcomm BCM57xx driver. * bsd_eth_drivers/if_bge/.cvsignore, bsd_eth_drivers/if_bge/Makefile.am, bsd_eth_drivers/if_bge/if_bge.c, bsd_eth_drivers/if_bge/if_bgereg.h: New files.
* bsd_eth_drivers/re/if_re.c: Almost runs.
2009-02-192009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-0/+4
* bsd_eth_drivers/libbsdport/sysbus.c: Revert Till's patch.
2009-02-192009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-0/+6
* bsd_eth_drivers/if_em/e1000_manage.c, bsd_eth_drivers/if_em/e1000_manage.h: New files. Missed in initial import.
* .cvsignore: Add Makefile.in
2009-02-19New file.Joel Sherrill1-0/+12
