Update #3533.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
This is an implementation detail of the EDF scheduler.
Global data was declared in system.h but should have been extern
in system.h and declared in init.c. There were duplicate symbol
linking errors on at least powerpc/mpc8260ads.
for details.
Add the lipqos and sptest.
