Make sure PER_CPU_DATA_OFFSET() is tested also in uniprocessor
configurations.
Use separator character '_' for all test states.
Update #3732.
Add uniprocessor version for PER_CPU_DATA_GET_BY_OFFSET(). Fix warnings
in uniprocessor configurations.
Update #3507.
Update #3507.
