Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
spmsgq_err01 test replaces rtems_message_queue_XXX error tests from
sp09 screen 7. spmsgq_err02 replaces rtems_message_queue_XXX error
tests from sp09 screen 8.
