Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Replace _Thread_Disable_dispatch() with _Thread_Dispatch_disable().
Replace _Thread_Enable_dispatch() with _Thread_Dispatch_enable().
This is a preparation to remove the Giant lock.
Update #2555.
Use a red-black tree instead of delta chains.
Close #2344.
Update #2554.
Update #2555.
Close #2606.
Use thread wait flags for synchronization. The enqueue operation is now
part of the initial critical section. This is the key change and
enables fine grained locking on SMP for objects using a thread queue
like semaphores and message queues.
Update #2273.
This avoids test durations of more than one hour on fast targets, since
fast targets can count a lot during one clock tick period, so the minor
loop iteration count was quite high. Estimate now the test body
duration to iterate only through the interesting time window.
Add and use interrupt_critical_section_test().
