This helps to reduce the use of architecture-specific defines throughout
the code base.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Update #3076.
On some systems, the instruction cache invalidation is not allowed by
the MMU.
Add rtems_cache_coherent_free() and rtems_cache_coherent_add_area().
Make sure also the size is cache aligned since otherwise we may have
some overlap with the next allocation block. A cache invalidate on this
area would be fatal.
l.nop instruction.
Add a local context structure to the SMP lock API for acquire and
release pairs. This context can be used to store the ISR level and
profiling information. It may be later used to enable more
sophisticated lock algorithms, e.g. MCS locks.
There is only one lock that cannot be used with a local context. This
is the per-CPU lock since here we would have to transfer the local
context through a context switch which is very complicated.
Add rtems_cache_get_data_cache_size() and
rtems_cache_get_instruction_cache_size().
A cache line cannot have a negative size.
