#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3732.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Rename _ISR_Disable_without_giant() into _ISR_Local_disable(). Rename
_ISR_Enable_without_giant() into _ISR_Local_enable().
This is a preparation to remove the Giant lock.
Update #2555.
Rely on test extension to report profiling.
Use events instead of suspend/resume.
Rename rtems_smp_get_processor_count() in rtems_get_processor_count().
Make rtems_get_processor_count() a function in uni-processor
configurations to enable ABI compatibility with SMP configurations.
Add a task producing memory traffic. Add tasks to obtain a priority
inheritance semaphore in a synchronized way.
