2019-12-19 | config: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS | Sebastian Huber | |
Rename CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS into CONFIGURE_MAXIMUM_FILE_DESCRIPTORS. Update #3753. | |||
2018-04-10 | testsuite/psxtests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | |
This change is part of the testsuite Makefile.am reorganization. Update #3382 | |||
2017-11-06 | tests: Use simple console driver | Sebastian Huber | |
Update #3170. Update #3199. | |||
2017-10-28 | tests: Remove TEST_INIT | Sebastian Huber | |
The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | |||
2017-10-23 | testsuite: Use printk for all test output where possible. | Chris Johns | |
- Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | |||
2014-03-25 | tests/psxtests: Use <rtems/test.h> | Sebastian Huber | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | |
2012-05-11 | psxtests - Eliminate missing prototype warnings | Joel Sherrill | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2012-05-11 | Filesystem: PR1398: Fix lseek() mechanic | Sebastian Huber | |
According to POSIX the lseek() function shall not, by itself, extend the size of a file. Remove the size field of rtems_libio_t. A file has only one size but may have multiple open file descriptors. Thus a file size field in the file descriptor may lead to inconsistencies. New default handlers rtems_filesystem_default_lseek_file() and rtems_filesystem_default_lseek_directory(). | |||
2012-05-07 | Revert: Remove CVS Ids | Joel Sherrill | |
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | |||
2012-05-04 | Remove CVS-Ids. | Ralf Corsépius | |
2012-02-01 | Remove all .cvsignore files. | Joel Sherrill | |
2011-12-08 | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
PR 1589/build * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am, psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am, psxaio03/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxclassic01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxeintr_join/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am, psxfile02/Makefile.am, psxfilelock01/Makefile.am, psxgetrusage01/Makefile.am, psxid01/Makefile.am, psximfs01/Makefile.am, psximfs02/Makefile.am, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxpasswd02/Makefile.am, psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxsignal06/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Remove obsolete optional manager capability. | |||
2011-02-22 | Add HAVE_CONFIG_H. | Ralf Corsepius | |
2010-08-09 | 2010-08-09 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
PR 1661/testing * psxchroot01/test.c, psximfs01/init.c, psximfs02/init.c, psxpipe01/init.c: Eliminate most references to RTEMS_Malloc_Heap. | |||
2010-08-07 | 2010-08-06 Bharath Suri <bharath.s.jois@gmail.com> | Joel Sherrill | |
PR 1654/testing * psx13/test.c, psx13/psx13.scn: Test case to improve testing of dup2 routine. * psxfile01/test.c, psxfile01/psxfile01.scn: New test to improve testing of fcntl routine. * psximfs01/init.c, psximfs01/psximfs01.scn: Improve testing of imfs routines. * psximfs02/init.c, psximfs02/psximfs02.scn: Improve coverage of imfs routines. * psxpasswd02/init.c, psxpasswd02/psxpasswd02.scn: New tests to improve coverage of getpwent.c. | |||
2010-07-29 | 2010-07-29 Bharath Suri <bharath.s.jois@gmail.com> | Joel Sherrill | |
PR 1633/testing * psximfs01/init.c, psximfs01/psximfs01.scn, psximfs01/psximfs01.doc: New cases to exercise IMFS_memfile_remove. | |||
2010-06-30 | 2010-06-30 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | |
* psximfs01/init.c: Fix warning introduced. | |||
2010-06-30 | 2010-06-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
PR 1595/tests * psximfs01/init.c: Fix warnings. | |||
2010-06-28 | 2010-06-28 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* Makefile.am, configure.ac: Add test to exercise IMFS behaviour with files of maximum sizes. * psximfs01/.cvsignore, psximfs01/Makefile.am, psximfs01/init.c, psximfs01/psximfs01.doc, psximfs01/psximfs01.scn: New files. |
