2019-12-19 | config: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS | Sebastian Huber | |
Rename CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS into CONFIGURE_MAXIMUM_FILE_DESCRIPTORS. Update #3753. | |||
2018-04-10 | testsuite/psxtests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | |
This change is part of the testsuite Makefile.am reorganization. Update #3382 | |||
2017-11-06 | tests: Use simple console driver | Sebastian Huber | |
Update #3170. Update #3199. | |||
2017-10-28 | tests: Remove TEST_INIT | Sebastian Huber | |
The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | |||
2017-10-23 | testsuite: Use printk for all test output where possible. | Chris Johns | |
- Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | |||
2014-11-20 | libcsupport: Implement getgroups() | Sebastian Huber | |
2014-03-25 | tests/psxtests: Use <rtems/test.h> | Sebastian Huber | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | |
2013-07-22 | testsuites: Include missing header files | Sebastian Huber | |
2012-05-11 | psxtests - Eliminate missing prototype warnings | Joel Sherrill | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2012-05-07 | Revert: Remove CVS Ids | Joel Sherrill | |
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | |||
2012-05-04 | Remove CVS-Ids. | Ralf Corsépius | |
2012-02-01 | Remove all .cvsignore files. | Joel Sherrill | |
2011-12-08 | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
PR 1589/build * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am, psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am, psxaio03/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxclassic01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxeintr_join/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am, psxfile02/Makefile.am, psxfilelock01/Makefile.am, psxgetrusage01/Makefile.am, psxid01/Makefile.am, psximfs01/Makefile.am, psximfs02/Makefile.am, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxpasswd02/Makefile.am, psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxsignal06/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Remove obsolete optional manager capability. | |||
2011-02-22 | Add HAVE_CONFIG_H. | Ralf Corsepius | |
2010-07-05 | 2010-07-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* psxid01/init.c, psxid01/psxid01.scn: Actually match an entry in /etc/passwd and /etc/group. | |||
* psxid01/init.c, psxid01/psxid01.doc, psxid01/psxid01.scn: Add test cases. | |||
2010-07-01 | 2010-07-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* Makefile.am, configure.ac: Add tests for file lock stubs as well as various POSIX methods that access UID, PID, and GID. * psxfilelock01/.cvsignore, psxfilelock01/Makefile.am, psxfilelock01/init.c, psxfilelock01/psxfilelock01.doc, psxfilelock01/psxfilelock01.scn, psxid01/.cvsignore, psxid01/Makefile.am, psxid01/init.c, psxid01/psxid01.doc, psxid01/psxid01.scn: New files. |
