2020-04-16 | Canonicalize config.h include | Sebastian Huber | |
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif | |||
2018-04-10 | testsuite/libtests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | |
This change is part of the testsuite Makefile.am reorganization. Update #3382 | |||
2017-11-06 | tests: Use simple console driver | Sebastian Huber | |
Update #3170. Update #3199. | |||
2017-10-28 | tests: Remove TEST_INIT | Sebastian Huber | |
The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | |||
2017-10-23 | testsuite: Use printk for all test output where possible. | Chris Johns | |
- Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | |||
2017-06-21 | rbheap01/init.c: Fix PAGE_SIZE redefined warning | Joel Sherrill | |
2015-09-11 | rbheap: Fix rtems_rbheap_free() | Sebastian Huber | |
Remove unused descriptor of merged free chunks from the free chain and add them to the spare descriptors. Close #2417. | |||
2015-09-11 | libtests/rbheap01: Simplify | Sebastian Huber | |
Update #2417. | |||
2015-08-31 | rbheap: Drop direction from _RBTree_Iterate() | Sebastian Huber | |
2014-08-05 | rbtree: Add and use RBTree_Compare_result | Sebastian Huber | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | |
2014-03-20 | tests/libtests: Use <rtems/test.h> | Sebastian Huber | |
2014-01-09 | libtests: Add contents to rbheap and stackchk documentation files | Cynthia Rempel | |
2013-11-21 | score/rbtree: Remove "unprotected" from API | Sebastian Huber | |
2013-07-23 | score: Create rbtree implementation header | Sebastian Huber | |
Move implementation specific parts of rbtree.h and rbtree.inl into new header file rbtreeimpl.h. The rbtree.h contains now only the application visible API. | |||
2012-12-22 | libtests/rbheap01: Add test cases | Sebastian Huber | |
2012-05-11 | libtmtests - Eliminate missing prototype warnings | Joel Sherrill | |
2012-04-18 | rbheap: API changes and documentation | Sebastian Huber | |
2012-04-11 | rbheap: New files | Sebastian Huber | |
In the Red-Black Tree Heap the administration data structures are not contained in the managed memory area. This can be used for example in a task stack allocator which protects the task stacks from access by other tasks. |
